Results 1 to 10 of 22
Thread: EML light
    Oct 2010
    Birmingham
    Default EML light
    hi, ive got a vectra c 07 cdti sri. the engine managment light comes on when i turn the ignition on but goes out when the car is started. i have read somewer after 30 engine starts it should go out. im sure i started it more than 30 times now becuase its been over a week but the light is still on. do i have to do it 30 consecutive times?
    if any1 can help
    cheers guys
    Could be a fault like the glow plugs that it sees each time the car is started but goes when its running
    Nov 2010
    London
    ive got the same motor and same occurence. Have done 5000 miles already and no problems, so id just ignore it mate.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Is it not meant to come on with the ignition, and go out when you start?
    Or does it stay on for a bit before going out?
    Nov 2010
    London
    i think its only a problem if it doesnt go out once the engine's started (obviously).
    Oct 2010
    Birmingham
    It used to come on when d ignition was turned on an then usually goes out, but last week or so it's stayin on unless startd
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    The missus has a 55 reg CDTI SRi 150. Just been out to check hers. EML light stays on with ignition, and goes out on startup. Hooked up my code reader and nothing stored. Car starts and drives fine, and good economy too
    Engine : 1.9 CDTi
    You shouldnt see it unless there is a stored fault.
    The car needs to go through a certain amount of 'driving cycles' before its sure the fault has been cleared.
    A driving cycle might include driving at a certain speed for a set time in each gear.
    Your better off getting the code cleared if you dont want to see it all the time. Either a Tech2 session or someone with another code reader like Op-com etc.
    Tony go back outside and just do clear codes anyway as pending codes are stored but sometimes dont show up on all code readers (I know Op-Com doest see pending codes)
    Oct 2010
    Birmingham
    Was thinking ov getting a reader myself. U know of any1 good ones, not 2 expensive?
    Oct 2010
    Birmingham
    Tony, is thy defo cz I'm sure it Neva used to before, unless i ain't noticed lol
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
eml goes out
