Results 1 to 10 of 25
Thread: timing chain rattle then slip 2.0dti y20dth engine
    Mar 2007
    dublin
    Default timing chain rattle then slip 2.0dti y20dth engine
    Hi all
    Noticed a rattle under load on my vectra last friday night,
    took it to the mechanic but chain slipped on the way and car stopped with yellow spanner light on.
    Took the rocker cover off today and the chain has a lot of play,
    Where do I go from here?
    Thanks in advance
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    If the chain "slipped" the car would have simply stopped and not even start afterwards. Does the engine run?
    Mar 2007
    dublin
    car stopped, will not start but it sounded like it was trying to.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Any weird rattle or anything?
    Sep 2010
    yorkshire
    dead rebuild time or new engine
    Jun 2009
    Middlesex
    Had the same problem with mine.Cost me a lot of money having the camshafts removed to investigate if any damage had been caused.Luckly no valve damage.Cause was failure of chain tensioner.
    Dobs.
    Mar 2007
    dublin
    thanks for the replies, car is gone to the mechanic now to get his verdict.
    If an engine is needed what are my options regarding what engine fits?
    Woulda vectra b 2.0 dti engine fit?
    cheers
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Quote Originally Posted by bran.c View Post
    cheers
    as far as i know only the last of the vec b 2.0dti had the y20dth in them, think 2001
    pre 01 were x20dth
    lincolnshire
    cheers
    mate o mine rang one afternnon with exactly the same symtoms but on a seat TDi , stuck a new belt kit on and its been spot on ever since ! the fact that it IS trying to start suggests that its not done any damage BUT as always , every car is different ! its upto you but i reckon its worth th risk of sticking a chain kit on it !
    Nov 2009
    Warrington
    Trim : SRI
    Mileage : 79000
    i did a cam belt on a clio that had snapped, timed it all up and fitted new belt, luckily it was fine. Unless you want to strip it down, just get a new chain and try it
  1. Replaced Timing Chain - Now Engine Whines !
    By Verns in forum Engine & Drivetrain
    Last Post: 13th June 2012, 22:33
  2. 2.2 direct.timing chain rattle.
    By Dobs in forum Engine & Drivetrain
    Last Post: 4th April 2012, 20:47
  3. Engine Problems 2.0DTi Y20DTH
    By Daniel89 in forum Engine & Drivetrain
    Last Post: 16th August 2011, 19:10
  4. Timing Belt or chain on 2.0DTi
    By John3v36 in forum Engine & Drivetrain
    Last Post: 7th August 2008, 20:02
  5. timing chain rattle
    By bundy b in forum Engine & Drivetrain
    Last Post: 27th June 2007, 20:06
vauxhall vectra 2.0 dti how to tell if timing chain snapped
https:www.vectra-c.comforumshowthread.php132650-timing-chain-rattle-then-slip-2-0dti-y20dth-engine
vauxhall zafira 2.0dti timing chain slipped
vectra c 2.0 dti engine rattle
y20dth
https:www.vectra-c.comforumshowthread.php132650-timing-chain-rattle-then-slip-2-0dti-y20dth-enginepage2
Y20DTH chain
rattling vauxhall diesel zafira 2.0 dti
vauxhall 2.0 dti engine timing belt or chain
2.0 dti cam chain
zafira 2.0 dti timming cain jumped
can a timing chain jump on a vauxhall zafira 2.0 dti
vauxhall signum timing chain slipped
zafira timing chain noise
vauxhall zafira 2.0dti timing chain sliped
zafira 2.0 dti timing marks
vauxhall zafira 2.0 dti cambelt or chain
vauxhall zafira y20dth timing chain removal
timing chain moved vauxhall 2.0dti
dti 2.2 timing chain failure
vectra 2.2 timing chain slipped
vauxhall signum 2.0dti rattle on timing chain
Vectra C 2.0 Dti timing chain problems
how to change timing chain on vauxhall vectra 2.0
