Thread: Help needed please
    Regular Member AndyFoz83's Avatar
    Jan 2010
    Wolves
    Default Help needed please
    I just had ago at cleaning my egr and throttle body now the car wont rev at all on start up ive got spanner light up and the engine light to, the fault that is being diplayed on the reader is P0400 Exhaust Gas Recirculation Flow Malfunction is that egr knackered and what can i do to get rid of it.. thanks for looking
    scottish region
    get the egr blanked and if the eml annoys you get the software took of the ecu
    Jan 2010
    Wolves
    ordered a blank off you dont think its the throttle body as well i hope not
    scottish region
    if its only showing egr then proberly not deffo connected everything back up properly
    Jan 2010
    Wolves
    been back out checked connections finished my can of pepsi cut the can up blocked it off to see wether it worked....... and she started up better than ever temp fix ordered a fiat blanking plate just need to get prices on a re-map thank you for your help....
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    The coke can isnt a good idea it will melt!, the bits will enter the manifold & head area, remove the egr again recheck & clean the elec solenoid end, your wasting time without doing both sides of the valve.
    Jul 2009
    The Rift, Cardiff
    There have been many posts on here about the can disintegrating, can only be bad news when it's entering the combustion process. As said make sure every thing is connected correctly.
    Jan 2010
    Wolves
    I only tried the can as a trial to see if that was the problem everything is connected properly egr is screwed. I cleaned it properly as it says on here and i have ordered a fiat blanking plate. Andy
  1. Amp help needed
    By minimission83 in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 22:17
  2. help needed
    By sebadee in forum Engine & Drivetrain
    Last Post: 21st January 2011, 19:57
  3. Help needed!!
    By seannygoat in forum Electrical & ICE (including SatNav)
    Last Post: 26th December 2010, 17:23
  4. Help Needed
    By Andie-100 in forum Engine & Drivetrain
    Last Post: 19th December 2010, 21:51
  5. How To Needed........
    By spennny in forum The 'Off Topic' room
    Last Post: 17th July 2009, 14:17
