Thread: Tech2 Interface
    Regular Member Kamikazy's Avatar
    Feb 2006
    United Arab Emirates
    lets you use a laptop with the appropriate tech2 software, instead of using the tech2 'palmtop'(must have big palms it's huge).
    it converts the OBD compliant socket to an RS232..
    Sweden
    Well yes .... but i says nothing of wich protocols it supports!
    Melbourne, Australia
    Quote Originally Posted by Gsi3.2
    ...with the appropriate tech2 software, instead of using the tech2
    Silly question, but is there "tech2 software" that runs on something other than a ("real") Tech 2 unit? Or is this just for reading trouble codes? In other words, can a laptop with this interface be used as a Tech 2 substitue? My guess is "no".
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    Ok i know a little about this subject, Most Vx Vectra used the canbus interface which I believe is ISO 15765-4. Tech2 software is specifically for the Tech2 handheld device which is manufactered by Vetronix, link to site http://www.hickleyvaltone.com/diagnostics/ad400.php
    Most laptops use software such as Scanmaster to interface with the ODB port via a provided lead with the package. You can in theory reset fault codes and check some live engine data. Although as of this data I'm having issue's with the software. This may be down to my car being FULL canbus but on earlier production models pre 05 it will work fine. The major thing these type of packages cannot do is to write to the ECU like the Tech2 can for such functions as altering menu options for turning devices on and off, adding extra items etc etc.
    HTH
  1. ODB Interface
    By Golfboy in forum Vectra C / Signum Car Chat
    Last Post: 1st October 2010, 14:12
  2. ELM 323 Interface
    By frenchman in forum Vectra C / Signum Car Chat
    Last Post: 22nd October 2009, 22:19
  3. Can Bus Interface
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 20th August 2008, 11:27
