Results 1 to 10 of 20
Thread: Handbrake adjustment
    Regular Member djr69uk's Avatar
    Midlands
    Default Handbrake adjustment
    Would this be part of a full main dealer service?
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    handbrake is self adjusting unless you have stretched the cable and need a new one
    Midlands
    Quote Originally Posted by neverlandandy View Post
    Hmm OK... the lever rises up a little too much for my liking. Sometimes hits the underside of the arm rest if I whack it on hard for hill parking etc..
    Nottinghamshire
    As above, it self-adjusts every time you pull the handbrake on unless you feel/hear a big clunk at some point when you are pulling the lever up in which case the self-adjusting mechanism in the handbrake lever unit may be failing causing excessive lever travel whenever it does this.
    This has happened on mine and I've got a new handbrake lever to fit. I asked about handbrake cables but the dealer said they'd never sold any so I decided to leave the existing ones on.
    The other thing is there there is an adjustment mechanism on the back of the handbrake lever unit - remove the panel below the rear power socket / cigarette lighter to reveal the bolt. However, neither Vauxhall or Haynes mention it at all...
    Feb 2011
    Mansfield, Nottinghamshire
    Quote Originally Posted by James24 View Post
    would fitting a new handbrake cure the clunk noise? mine has done it a few times!
    Nottinghamshire
    Quote Originally Posted by Collis View Post
    No, that's most likely not the cables. Remove the rear part of the centre console to reveal the handbrake adjuster mechanism at the base of the handbrake unit then chock the wheels and just keep applying the handbrake and watching the mechanism to see if it slips when the the clunk is felt/heard.
    If this is the problem, then you need a new handbrake lever assembly and locking (celvis) pin from a dealer for about £100. You have to remove the exhaust (theoretically the whole lot, but I've managed just to remove the rear and centre sections on my DTi) and the front silencer heatshield as well as the rear section of the centre console to replace it. If you have a CDTi, there may be the DPF to consider as well, but I don't know as I haven't got one.
    Regular Member recoveryman's Avatar
    glasgow
    Vehicle : vectra
    Trim : elite
    Engine : 1.8 petrol
    Mileage : 92000
    take your car to stealers get it done free of charge i have just recieved a call back letter to take it in for a handbrake mod lol the car is only 8 yrs old now god knows why they sent me the letter but hey ho im taking it in
    Feb 2011
    I spoke to them the other day. They told me there wasnt a recall on it. Ive read on here that there is.
    Is it worth giving another vx dealership a call?
    Mark
    Midlands
    Mark
    Yes... there was definitely a recall on the handbrake.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    How are the rear pads looking!, if there ok it maybe a sticking caliper/piston or streched cable.
  1. Handbrake adjustment
    By jrh1 in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 19:40
  2. handbrake adjustment???
    By craigleeds in forum Suspension, Wheels & Brakes
    Last Post: 27th May 2011, 03:43
  3. MPG adjustment on Op.com
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:40
  4. 1.8 sxi handbrake adjustment
    By Paul4274 in forum Suspension, Wheels & Brakes
    Last Post: 12th June 2009, 16:26
opel vectra c handbrake adjustment
vectra c handbrake adjuster
vauxhall vectra c handbrake adjustmentvectra c handbrakevauxhall vectra handbrake problemso4 vauxhall vectra hand brake ajustmentvauxhall vectra 2006 handbrake too tightvauxhall vectra handbrake cable adjustmentvauxhall vectra c handbrake adjustvauxhall vectra c handbrake cableadjust handbrake vauzhall omegavauxhall vectra adjuhow to adjust hand brake vauxhall vectravectra 2008 handbrake adjustmentvectra handbrake adjustmentfitting a vectra hand brake cablehow to adjust the handbrake on a vauxhall vectra elite 2007tighten hand brake vectra clot of give in vectra handbrakevauxhall vectra handbrake adjustmenttighten handbrake vectra cvectra handbrake problemsvauxhall vectra 1.8 c handbrake adjustmenthand brake adjustment
