Thread: Help!, cant get hose off thermostat!
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default Help!, cant get hose off thermostat!
    any ideas?
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Hose Or Clip Thats Stuck ?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    grip with pipe grips and twist to crack the seal
    lincolnshire
    what he said ! i hate doing the stat on the 120 cdti , its a *****
    Feb 2011
    Selby
    Really common for rubber hoses to get stuck onto aluminium pipes, it's just the oxides that form naturally acting as a glue.
    Whatever you do, don't pull the hose, as you'll stretch it and break all the internal structure that stops it ballooning, or even tear it. Instead, push and twist it to break the seal - wrapping it tightly with a rag to prevent damage to the rubber and using mole grips or Stilsons works well.
    Once the pipe's free to move, then pull it off. Give the metal a quick clean up to remove any corrosion, and also give the inside of the end of the pipe a wipe too, so that when you put it back on it'll seal nicely without having to have the hose clamp excessively tight.
    Oct 2007
    south wales
    well just finished it, only one casualty, a bracket bolt that sheared off due to my cack handedness, thank goodness for cable ties!
    just run it for 10 mins, going to let it cool, top it up and take it for a spin.
    I took the thermostat off with the hose attached to get more leverage, then used a spoon to loosen the rubber...
    Sep 2010
    oops ... read properly
  1. What hose is this??
    By glasgowdarren in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2012, 22:04
  2. Hose Size?
    By Governor in forum Diesel Engine related
    Last Post: 5th June 2012, 18:04
  3. Name of tool for opening hose clips on Vectra C thermostat connections?
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2012, 06:32
  4. Name that hose?
    By garetmcc79 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th May 2012, 17:09
  5. vac hose on 3.2
    By hagga in forum Engine & Drivetrain
    Last Post: 3rd July 2007, 16:48
