Results 1 to 10 of 19
Thread: Problems after the Y30DT engine switch.
    Sep 2010
    Finland
    Default Problems after the Y30DT engine switch.
    Hi, concerned Opel Signum 3.0 CDTI 2005 and Y30DT engine.
    I changed to a new engine and everything should be ok but the engine will not start. Any running problems or start-up problems were not the old engine, before the exchange. (except the BIG bearing faults). Nozzles have been checked and all the fuel connections used new gaskets.
    Would it be the fault codes that prevent the engine from starting? Or high-pressure pump??
    Does anyone have doubts or experience about this problem?
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Did you also swap the ECU? as most parts need coding.. so everything you did take from the donor car.. needs to be coded to yours..
    Sep 2010
    Finland
    Quote Originally Posted by kenp View Post
    Yes, the ECU was loose in 3 weeks, like almost all the parts. Do you know, can I update the ECU by own fault code reader? (Sorry for the bad English but did you understood what I meant)?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I don't see why it wouldn't start if you're using your old ECU's (there are 2!!!). And yes, I believe you could reset the ECU with a code reader and then reprogram the immobiliser.
    Engine : 2.2 Direct
    Sep 2010
    Finland
    LIke I said, my english is bad...
    Anyway, all parts are from old engine. But if ecu is out of position many weeks so is it possible that the settings disappear from that box?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by jaakoppi View Post
    Let's put it this way...
    When I used my old phone (dead battery for 1 year) all the names were still in!
    Are you getting fuel to the injectors?
    Engine : 2.2 Direct
    It could happen, but it shouldnt happen..
    Sep 2010
    Finland
    Quote Originally Posted by Celes View Post
    Ok. Im not sure is there fuel in injectors?? How can I check it? In this engine injectors are inside the valve cover and on top is a lot of stuff, so the injector, it is difficult get sight.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I know
    Un-tight the pipes that go into the injectors. I think cylinder 6 is the easiest to get to Then ask someone to crank the car while you watch if there is a dribble of diesel coming from there
  1. anyone changed glow plugs on y30dt engine or 3.0 v6 cdti?
    By signum03 in forum Vectra C / Signum Car Chat
    Last Post: 5th May 2011, 15:24
  2. oil filter question for y30dt engine(3.0 v6)
    Last Post: 27th January 2010, 22:18
  3. How many dealerships / Vectra C with Y30DT engine
    By m8internet in forum Vectra C / Signum Car Chat
    Last Post: 27th September 2009, 12:46
  4. 3.0 CDTi Y30DT engine oil temperature
    By Celes in forum Engine & Drivetrain
    Last Post: 16th July 2009, 22:48
  5. y30dt engine
    By phil0464 in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2008, 16:53
y30dt problems
y 30 dt motor
https:www.vectra-c.comforumshowthread.php132618-Problems-after-the-Y30DT-engine-switch
motor vectrac y30dt
y30dt motor
y30dt engine update
