Thread: drivers door check strap busted
    Mar 2011
    Glasgow
    Default drivers door check strap busted
    Part of the door has come off where the check strap top screw goes in next to the door card. Any one got a check strap I could buy from them
    Woodbridge
    they are cheap enough from VX mate
    newport
    really need to do mine, clicks really bad when opening the drivers door. does the door card have to come off to change it?
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    it does indeed. Really simple and quick job..very satisfying too!!
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    Quote Originally Posted by taffy bhoy View Post
    no there is a how to to fix a clicking check strap
    you need to unbolt from a post twist strap 180 degrees then unbolt from door and twist 180 degrees and bolt it all back up jobs a good un
    swansea
    On my facelift, the door bolts have the nut on the outside, with the head on the inside. You would have to be very lucky to be able to undo these without them falling into the door.
    Quote Originally Posted by jrh1 View Post
    the head on the inside it welded to the door check link so they wont fall inside the door if you remove the nuts
    stratford upon avon
    Vehicle : vectra c
    Trim : ls
    Engine : 1800 non vvt
    Mileage : 137000
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    http://www.vectra-c.com/forum/showth...t=90773&page=3
    Post N0 24. All about rotating strap. And it works. tried it on mine. Like new again.
  1. Check Strap Clicking/Knocking Door noise
    By msqualo in forum Bodywork & Interior
    Last Post: 1st June 2012, 13:02
  2. Door Check Strap!
    By @ndy-e in forum Bodywork & Interior
    Last Post: 5th October 2009, 15:01
