Thread: laptop tech help please
    Regular Member neill's Avatar
    Nov 2009
    Warrington
    Vehicle : Vectra C estate
    Trim : SRI
    Mileage : 79000
    Default laptop tech help please
    Hi, ive got an acer 8935g laptop that needs recovering. Ive tried to use my self made recovery discs but one of them is scratched so will not work.
    And ive tried to use the recovery partition but when i press alt & f10 at boot, it comes up with ntldr is missing, ctrl alt del to restart.
    The recovery partioin which is hidden shows up in disk management so im assuming its intact, apart from the ntldr.
    Is there anyway i can restore the ntldr for the recovery partition, i have spoke to acer but they said they will fix it for a fee
    please help, as its really frustrating.
    many thanks
    New Member monza68's Avatar
    Mar 2011
    wallasey
    Default maybe this mite help
    It sounds like you got a virus on your hard drive .Run it in safe mode and try a antivirus of a usb stick or external hard drive . Then run it this should find the virus which is blocking system restart,once done you can restart from a last good configuration .hope this is some help james
    Regular Member nikroc's Avatar
    Nov 2007
    DERBY
    17 Post(s)
    Vehicle : 2t
    Trim : standard
    Engine : z20net
    Year : 08
    Mileage : 32000
    i guess it depends on why you need to use the restore process tbh. Was/is the disc dropping files?..heavily loaded and slow?..infected?..it may be simpler if you were to replace the hard drive and put the original in a usb caddy to work off..if you can replace the missing file(s)..this way you could upgrade the size of your hard drive!!
    Jan 2010
    glasgow
    hi bud i had the same problem think it was a virus that did it as it was mega slow, go on to acer web site and down load all the drivers,is your ethernet ok or has it got a yellow icon next to it when you have got all the drivers if you have a windows disc reformat it and install the drivers if no windows disk try going into device manager and try updating the drivers put the driver files on a disc and tell the pc to look on the disc when you try updating the ethernet etc
  1. new laptop help
    By montyfert in forum General Chat
    Last Post: 14th February 2012, 20:44
  2. Using the laptop thru the TV
    By KeefyB in forum General Chat
    Last Post: 30th August 2010, 12:51
  3. Another new laptop....
    By PAULMAC77 in forum The 'Off Topic' room
    Last Post: 7th April 2010, 20:05
  4. OBD II Laptop
    By lofty in forum General items for sale
    Last Post: 21st January 2008, 15:51
  5. What laptop?
    By JoolsV6Elite in forum General Chat
    Last Post: 2nd December 2007, 23:15
