Results 1 to 10 of 13
Thread: arm rest vent?
    Regular Member larrygroke's Avatar
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    Default arm rest vent?
    hey all does anyone know where i can get the air vent for the arm rest at the back?
    regards
    Larry
    Regular Member shb1988's Avatar
    Oct 2010
    sittingbourne
    i've seen them on ebay but i'm curious as to whther mine will have the set up to allow air to the vents?
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    to see if its set up pop open the rear cig lighter socket and then the gap which mine is will come off and you should see a pipe coming up through! can you see any on ebay at the moment i cant find one anywhere?
    Oct 2010
    sittingbourne
    so i have to take the rear sig lighter out or will i be able to see through?
    here is one quite cheap too
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...#ht_1009wt_905
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    if you use a small screwdriver you can just pop out the whole plate with the cig lighter on and if you move it to one side and look through the gap which you have made by removing it you should see a pipe hope this helps
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    that arm rest you have seen u can pop the vent out also!
    Oct 2010
    sittingbourne
    excellent cheers i will have a look
    Feb 2011
    Plymouth
    Vehicle : vectra c
    Trim : Exlusive
    no probs!
    Beware that people have tried retrofitting them but found there simply isn't any flow - the models which have it from the factory have a different and more powerful blower motor I believe. If you take it apart and find the pipework underneath you might be lucky, but it's worth checking the flow that comes out of it first before you buy anything...
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Quote Originally Posted by larrygroke View Post
    How Does The Vent Pop Out ?
  1. arm rest
    By tonci26 in forum Detailing and Car Care Discussion
    Last Post: 4th February 2013, 00:14
  2. new car (and the rest lol)
    By gallag in forum Vectra C / Signum Car Chat
    Last Post: 20th April 2010, 20:07
  3. How to fit a Arm Rest
    By AndyFoz83 in forum Bodywork & Interior
    Last Post: 3rd February 2010, 15:20
  4. Arm rest
    By bigmac in forum Styling
    Last Post: 3rd November 2008, 22:58
