Thread: vectra c fog light grill
    Mar 2011
    dagenham
    Default vectra c fog light grill
    hi just wondered if any knows how to take the drivers side fog light grill off?? cheers
    Regular Member Envy's Avatar
    Welwyn Garden City
    Trim : SRi Nav
    Engine : 1.8 VVT
    Mileage : 130k
    Hi there.
    I needed to get mine off (06 Facelift Vec) to put on signum ones instead.
    I went the whole hog and removed the front bumper. I know it sounds like a lot of work but it meant i could get to everything for easy removal and re fit.
    Before that I removed the front to look at a fog light that was filled with water and to correct some lining up issues. Have a look here for instructions http://www.alfworld.co.uk/vectra/
    I did make a slight mistake with pointing out the screws to remove at the front. I included two screws that are part of the light housings. Ignore them.
    Hope this helps.
    EDIT : Oh I forgot to mention that you will have two leads connecting to the Fogs and a temp sensor connection on the nearside that need to be disconnected with care when taking off the front. An extra pair of hands at this stage is handy but it can be done on your own.
    scottish region
    yep take the bumper and hole fog lamp unit out completly
    Vectra-sport Admin Dre's Avatar
    Vectra-sport Admin
    Vehicle : VXD
    lower the bumper off the car as it will be easier and just pop the tabs out of the grill with a flat blade screw driver
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Hi as I know you just want to take the plastic fog light cover off, right? If yes, just grab it and pull just be careful not to damage plastic clicks and that's all.
    Oct 2007
    Ripon
    How did you end up taking them off? Looking at removing mine...... Seen some threads that you can just pull them out....?
    What's the best and easiest way?
  1. Part no on fog light grill surrounds
    By Mopar Man in forum Styling
    Last Post: 24th February 2011, 15:13
  2. Facelift lower grill and fog light blanks
    By bertbuckie1 in forum Parts for sale
    Last Post: 28th March 2009, 11:56
How to change fog light surrounds vectra c www.vectra-c.com
vectra c foglught grill removal
