Thread: vectra c wiring loom connectors
    Mar 2011
    wilts
    Default vectra c wiring loom connectors
    as Ive posted elsewhere, more has appeared.
    got a new garmin for my birthday, wont work on front ciggy lighter but does work on back one!!
    so to recap, 2003 vectra c 3.2 gsi. rear boot light works.
    rear cigarette lighter works.
    glove compartment light has been disconnected, (got to find the wires).
    front cigarette lighter does not work.
    interior door lights dont work.
    interior reading lights dont work.
    called in to Platinum Vauxhall when the coded my new key, but they say there is no interior light circuit fuse they can find on diagram, I couldnt find one on downloaded 2007 handbook either.
    can anyone shed some light on this please.
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    The interior lighting is controlled via the body control module..
    This uses the fuses in the end of the dash..
    Check the fuses in the end of the dash..
    Particularly,
    F4 where fitted - some BCM functions
    F7 and / or F9 - Some BCM functions
    F12 - Overload protection fuse... the most common failure fuse
    F17 and F19 - Some BCM functions
    Fuse F12 often blows when people cause a short circuit in and around the glove box light !!
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    just had a look at wiring diagrams on tis and it appears that the rear
    accessory socket is linked to the front accessory socket and also links
    upto fuse f22 in the passenger side fusebox
    Mar 2011
    wilts
    thanks but have now found inner roof loom has been cut so have to sort that out
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    That is very clumsy of someone... I assume they may have done this when fitting a rear interior light...
    They must have missed with the stanley knife when trimming the roof lining for the light holding bracket.
    I have heard of this before...
    Mar 2011
    wilts
    Robsey, it was the police vehicle department, being an ex police car they made a few mods, looks like instead of removing bulbs they cut the loom. the wires are heatshrunk to the end of the ribbon, will post pic if I can.
    what I can do with is a reminder where the ariel wire goes. left or right side of screen?
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    From memory, the aerial wire goes along the right side of the screen..
    The main aerial junction box is in the driver's footwell.
    The interior lighting ribbon runs along the left side of the roof panel, and towards the centre behind the sun-visors.
    Mar 2011
    wilts
    thanks
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Forgot to say.. the ribbon cable for the interior light,ultra-sonic sensors, auto-dimming rear-view mirror, rain and light sensors, rear interior light, all originate from the rear fuse box (REC).
    Depending which items are fitted to your car, determines which specific roof ribbon cable you have
  1. Vectra wiring loom question
    By pompey-pimp in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2012, 20:25
  2. What wiring connectors i need to fit aftermarket stereo and still have OBC
    By daftvectralad in forum Electrical & ICE (including SatNav)
    Last Post: 11th November 2008, 14:04
  3. Vectra 52 Phone wiring loom?
    By vivaciti in forum Electrical & ICE (including SatNav)
    Last Post: 13th July 2008, 15:40
vectra engine wiring loom connectors for security
https:www.vectra-c.comforumshowthread.php132592-vectra-c-wiring-loom-connectors
vectra c rear lights wiring diagram
has my 2005 vectra c got the wiring loom for interior rear light
vauxhall vectra c autodimming rear view mirror wires
vectra c boot fuse box wiring
vectra c light bulb wiring
vectra c auto dim connectors sri
vectra c cigar lighter spare wire
vauxhall vectra c inner loom lighting ribbon cable
vectra c urec connector
vectra c engine bay diagram
vectra c boot wiring diagram
vectra c wiring diagram map lights
holden vectra-c boot fuse box ribbon cable
how can i get a wire from the engine bay to the footwell in a vectra c
vectra c connector in roof lining at the front
vectra testing wiring loom
vectra c rear electrical centre site:www.vectra-c.com
