Thread: Possible Fuel Pump? Vectra 2.2 Direct
    Blackpool
    Default Possible Fuel Pump? Vectra 2.2 Direct
    Hi Guys,
    Having major problems with the car! What I thought was a problem with the 02 Sensor turned out not to be I will explain what happens!
    Some times it doesn't start just tickes/clicks?
    Then sometimes it goes into limp mode?
    Can turn it on and of and it will drive?
    When you try to go it's it runs like a dog, limps and judders?
    Fuel pump or fuel pressure regulator?
    Prices?
    Thanks!
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    pressure sensor first if not pump what year miles you got?
    Blackpool
    It's done 117k so quite high! Can sometimes drive spot on you see?
    What's the part number for the sensor? prices? Easy to fit?
    Thanks in advance!
    Aug 2010
    Luton
    its about 60 quid fitted at the dealer I think will have a look through my paper work later for number if no one else knows it
    Blackpool
    Got it - 24418424 Be great if you could confirm.
    Does it sound more like this then the pump mate?
    Aug 2010
    Luton
    no when the pumps go you get nothing when the sensors go they mess around for ages then pack up
  1. 2.2 direct fuel pump and fuel pressure regulator
    By w111y in forum Engine & Drivetrain
    Last Post: 11th July 2012, 22:12
  2. vectra 2.2 sri direct fuel pump problem
    By mh99 in forum Engine & Drivetrain
    Last Post: 18th September 2011, 06:51
  3. Vectra C direct 2.2i fuel pump failure
    By davidu in forum Introduce yourself.
    Last Post: 19th September 2010, 23:58
  4. Vectra C 2.2 Direct - high pressure fuel pump
    By johnmac in forum Engine & Drivetrain
    Last Post: 28th December 2007, 01:21
