Thread: Help.car will not start.a mind of it's own.
    Jun 2009
    Middlesex
    Default Help.car will not start.a mind of it's own.
    Went to start car tonight.Engine failed to turn,radio display switching itself on & off continuous,rear indicators flashing on there own.On central display a warning about check lights etc,mileage range displays a letter 'F' unable to lock doors,a car with a complete mind of it's own.Anybody with any idea's?Please help.Will keep you updated.
    Dobs.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Battery's probably dead, usually caused by faulty alternator. Try another battery on the car if you've got access to one (or charge yours), if it works, then the chances are your alternator's on the way out.
    Jun 2009
    Middlesex
    Do i need to know anythink before removing battery from car.Is it safe just to undo battery terminals remove battery & recharge.When i put battery in do i just reconnect and try to start car.
    Dobs.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Yup, only thing you need to know is your radio code if its a preface and you have the original radio fitted still.
    Jun 2009
    Middlesex
    Is it safe to use jump leads to see if the car will start.How many numbers make up the radio code?
    Dobs.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Yes
    Four, it will be on your car pass (Credit card sized bit of card with all the car security numbers on it).
    Jun 2009
    Middlesex
    I have the car pass.I have 4 numbers / 4 numbers.Are the first 4 the radio type and the second 4 the radio code.Any idea how to enter the code.Having how changed the battery which seems to have been the problem the radio display now shows SAFE.
    Dobs
    Regular Member fingers66's Avatar
    Carpe Diem
    Turn radio off, turn ignition off, press and hold the AS button and turn ignition on, turn radio on still holding AS button on, wait for beep and display to change then use the number buttons 1 to 4 to enter the code and press and hold AS button again till it beeps and display changes.
    Jun 2009
    Middlesex
    I will try tomorrow and let you know.
    Dobs
  1. Not quite what i had in mind
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 22nd April 2012, 21:34
  2. my car has a mind of it's own
    By john1 in forum Suspension, Wheels & Brakes
    Last Post: 19th November 2011, 22:32
  3. Mind how you go sir...
    By MrT in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2009, 00:18
  4. bit of help if u don't mind.
    By wanna veccy in forum The 'Off Topic' room
    Last Post: 7th November 2008, 11:14
  5. Mind of it's own
    By jimmy55 in forum Engine & Drivetrain
    Last Post: 15th July 2008, 21:01
