Thread: help my boot wont open ater removeing chrome strip
    Dec 2010
    IRELAND
    Default help my boot wont open ater removeing chrome strip
    .i removed my chrome rear strip for painting but i closed the boot by mistake and now it wont open .i have tryed the emergency key thing in the boot but no joy i can hear a winging sound but it wont open .cud the lock be out of alignment from removeing the boot strip? it was working fine before i took the chrome stripe off
    scottish region
    is the boot shut properly if not shut it then press the button
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    my boot motor is knackered and i have to hold the button in and lift the boot up thand push it down quite firmly till it clicks and unlocks
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    if you've removed the chrome strip you'll of had to remove to nuts which hold the lock actuator button to the chrome strip, so you'll be pressing the button but it wont be hitting anything behind it. You will need to remove the boot trim somehow to get to it.
    Dec 2010
    IRELAND
    Thanks mate thats what the problem is. Im lucky because i didnt put the boot trim back on so easy accass i havent put the boot strip on either as its just painted but when i put the stip back on and bolt it back together should the problem be sorted ?
  1. Boot wont open
    By LeylandRick in forum Vectra C / Signum Car Chat
    Last Post: 13th April 2012, 12:20
  2. Boot wont open???
    By fastcarmanaic in forum Bodywork & Interior
    Last Post: 18th November 2010, 15:14
  3. Boot wont open help!!
    By lukesignum in forum Bodywork & Interior
    Last Post: 6th March 2010, 15:21
  4. Boot wont open!
    By Netstar in forum Electrical & ICE (including SatNav)
    Last Post: 11th December 2009, 14:13
  5. Boot wont open !!
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 10th May 2008, 13:43
how to remove vectra c rear chrome strip www.vectra-c.com
