Thread: vectra 1.9 cdti 150 smoking
    Sep 2010
    preston
    Default vectra 1.9 cdti 150 smoking
    hi my 150 vectra has developed a missfire and started with white smoke out the back which improves as the car warms up, what could it be? I suspect an injector may be dripping into the cylinder when not running is this possible? if so how do you replace an injector and does it need to be programmed or is it a case of put a new injector in and the car will/should run, sorry forgot to mention the smoke smells of diesel not oil or water
    Last edited by blakester9; 16th March 2011 at 15:34. Reason: made a mess, first post
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Sounds like injector to me you wpuld need to replace the said I Hector there is a how2 on here in the how 2 section and yes the injector needs to be programmed to the car you will need someone with opcom or tech2 to do this
    Sep 2010
    preston
    Default more info
    is the programming easy to do, if i was to buy the op com kit? or is there a way to get the injector repaired, also i am jumping the gun, how do i find which injector is faulty?
    kings lynn, norfolk
    Either a leak off test or an injector specialist or opcom to see the deviation of the injectors will do
    Reprogramming is easy wit opcom all you do is delete the old injector code an type in the new one which is stamped on the injector
  1. Smoking cdti 120??
    By frasedeb in forum Engine & Drivetrain
    Last Post: 6th July 2012, 15:02
  2. V6 CDTI SMOKING...... but just once!?
    By BigWilko in forum Y & Z30DT Specific
    Last Post: 30th April 2012, 22:29
  3. vectra cdti 1.9 120 smoking
    By stj in forum Engine & Drivetrain
    Last Post: 17th February 2012, 18:51
  4. vectra sri 1.9 cdti 150 smoking badly
    By rickjames2610 in forum Vectra C / Signum Car Chat
    Last Post: 25th December 2010, 19:49
  5. Smoking CDTI
    By km101 in forum Engine & Drivetrain
    Last Post: 10th January 2007, 22:07
