Results 1 to 10 of 14
Thread: suspect faulty injector 1.9 cdti 150
    Sep 2010
    preston
    Default suspect faulty injector 1.9 cdti 150
    hi this is my first post but have used the site for past year for advice by searching my issues,
    my vectra 1.9 cdti has started to missfire slightly and emit white smoke that smells of diesel, I suspect a faulty injector could this be the case if so how do i change the injector do i need to be able to plug in tech 2 etc? if not what else could this be? the problem improves as the car warms up
    Engine : 1.9 CDTi
    It will need to be coded to the engine with Tech2 or Op-com etc
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    I can get them reconditioned the works and returned in 24hours if you wish.
    Very good friend of mine does this as a service on various forums -
    http://www.migweb.co.uk/forums/items...g-testing.html
    Kev
    Sep 2010
    preston
    Default injectors refurbished
    hi kev very impressed with the idea of your mate cleaning etc my injectors, don't want to sound to stupid but if i mark my injector 1-10 or write the code off each injector down to which cylinder it comes from, I guess there would be no need to reprogram? also your mate would rule out any injector issue's?
    Sep 2010
    preston
    sorry i don't know why i put 1-10 i meant 1-4 obviously (must be dreaming of a v10)
    Jul 2009
    id bag them up possibly and label the bags. He will test them all and then the see what the issue is IF there is one with the injectors and repair them if needed. I know the other week he did some for a golf that got a misfire and the machine replicated different throttle powers so full power, half power, light power etc and he found the fault and fixed it.
    Id email him - classicswirral@hotmail.com
    say Kev sent you and he will sort it asap
    Sep 2010
    preston
    would they just go back in with no programming needed though?
    Jul 2009
    as far as i know yes but id check with Nige on that email as he knows better than myself sorry
    Engine : 1.9 CDTi
    Each injector has a number on it.
    As long as that same injector goes back into that same position they wont need to be programmed when you re fit them.
    East Ayrshire
    Trim : SRI XP1
    mine have just been through this. they seem to be fixed and everything is getting put back together. i'll let you know how it goes
  1. Replies: 15
    Last Post: 27th September 2013, 00:22
  2. 3.0v6 cdti 183BHP 06plate loss of power.EGR valve suspect
    By tonydyett in forum Y & Z30DT Specific
    Last Post: 28th June 2013, 19:34
  3. Replies: 0
    Last Post: 16th December 2012, 16:46
  4. Suspect Injector Problem
    By DAVO in forum Engine & Drivetrain
    Last Post: 3rd December 2007, 16:59
  5. faulty injector
    By derby4life in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2007, 19:30
