Thanks Thanks:  1
Likes Likes:  1
Results 1 to 10 of 11
Thread: Pre-face vec c fuse, relays and earth locations
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default Pre-face vec c fuse, relays and earth locations
    Earth Locations
    E1 Engine Compartment strut tower RH Side
    E2 RH 'A' Pillar
    E3 Instrument panel cross member front passenger side
    E4 LH Engine Compartment
    E5 Instrument panel cross member front passenger side
    E6 LH front frame side member
    E7 Rear panel RH side
    E8 Transmission tunnel
    E9 LH 'A' Pillar
    E10 Engine starter/alternator
    E11 RH 'C' Pillar
    E12 Rear panel LH side
    E13 On Engine
    E14 Steering Column Bracket
    E15 On Tailgate
    E16 Engine Compartment Strut Tower LH side
    E17 Rear panel RH side
    Engine Fuse Box
    F1 Engine Management, automatic transmission 20A
    F2 Starter 25A
    F3 Horn 15A
    F4 Air conditioning, climate control 10A
    F5 Headlamp washer 15A
    F6 -
    F7 ESP, Central Control Unit 15A
    F8 Headlights, heated washer 10A
    F9 Power Steering 7.5A
    F10 Adaptive Lighting 10A
    F11 Windscreen wiper 30A
    F12 Windscreen wiper 30A
    F13 Central control unit, ESP 7.5A
    F14 Headlight washer system 30A
    F15 Engine control unit 10A
    F16 ABS 7.5A
    F17 -
    F18 -
    F19 Adaptive Lighting 10A
    F19 Headlight levelling 5A
    F19 Xenon Headlights 15A
    F20 Headlight levelling 5A
    F21 -
    F22 Wash/wipe 30A
    F23 Auxiliary heating 20A
    F24 Battery voltage, terminal 30 30A
    F25 Battery voltage, terminal 30 30A
    F26 -
    F27 -
    F28 Tailgate module Control unit 60A
    F29 ABS 40A
    F30 Tailgate module Control unit 60A
    F31 Vehicle interior module control unit 60A
    F32 ABS 40A
    F33 Vehicle Interior module control unit 60A
    F34 Tailgate module control unit 60A
    F35 Engine cooling fan 30A
    F36 Engine cooling fan 20A
    F37 Adaptive lighting (slot changing lighting for abroad) -
    F38 -
    Relays
    1 -
    2 -
    3 -
    4 -
    5 Engine Control Relay
    6 Starter Motor Relay
    7 Windscreen Wiper Motor Relay (on/off)
    8 -
    9 Ignition Main Circuits Relay 3
    10 Windscreen Wiper Motor Relay (low/high wiper speed)
    11 Headlamp washer relay
    12 -
    13 -
    14 A/C Compressor Clutch relay
    Engine Bay 2
    F38 Starter Motor 30A
    F39 Horn 20A
    F40 -
    F41 -
    Relays
    1 -
    2 -
    3 Fuel Heater Relay
    Passenger Fascia
    F1 Infotainment system, DVD 20A
    F2 Heater blow, heating, air conditioning 7.5A
    F3 Sunroof 20A
    F4 -
    F5 Door control unit 7.5A
    F6 Break light 7.5A
    F7 Body control unit [B30A][/B]
    F8 LH front door control unit 30A
    F9 Central control unit 7.5A
    F10 Steering column control unit 7.5A
    F11 Diagnostic connector 7.5A
    F12 Battery Control unit 15A
    F13 -
    F14 -
    F15 RH front door control unit 30A
    F16 -
    F17 Instrument, info display 15A
    F18 Ignition Terminal 15, air conditioning 7.5A
    F19 -
    F20 Yaw sensor (ESP) 7.5A
    F21 Telematics 7.5A
    F22 Cigar lighter, DVD 30A
    F23 Heater blower, air conditioning, climate control 40A
    F24 -
    F25 Heating, air conditioning 7.5A
    F26 Instruments, info display 7.5A
    Relays
    1 Ignition main circuits relay 2
    2 -
    3 Heater blow relay
    Rear Load Area
    F1 -
    F2 -
    F3 Electric Seat adjustment 40A
    F4 Heated rear window 40A
    F5 Electric seat adjustment 40A
    F6 RH rear electric window 30A
    F7 LH Rear electric window 30A
    F8 RH rear seat heater 15A
    F9 Horn, alarm 15A
    F10 Fuel pump 20A
    F11 Battery voltage 25A
    F12 LH rear seat heater 15A
    F13 Towing equipment 20A
    F14 Rear wiper 15A
    F15 LH front seat heater 15A
    F16 RH front seat heater 15A
    F17 Accessory socket 15A
    F18 Tailgate lock 30A
    F19 Terminal 30 10A
    F20 Central locking 7.5A
    F21 Alarm 5A
    F22 Electrically operated tailgate 30A
    F23 Alarm 7.5A
    F24 Battery voltage 25A
    F25 Electronic chassis 10A
    F26 Terminal 15 (ignition lock), travel assistant 25A
    F27 Seat occupant recognition, tyre pressure monitor, rain sensor, air conditioning) 5A
    F28 Parking distance sensor 7.5A
    F29 -
    Relays
    1 Rear screen wiper relay
    2 -
    3 Seat heater relay - LH rear
    4 Seat heater relay - RH rear
    5 Alarm system horn relay
    6-
    7 Central locking relay - fuel filler cap
    8-
    9 Ignition main circuits relay 4
    10 Heated rear window relay
    11 Fuel pump relay
    This list has been put together by me via the Haynes manual
    Last edited by plasma; 11th July 2016 at 19:02. Reason: pictures removed due to copyright violation. Please be aware of using other peoples/organisations pictures...
  2. Thanks welshhuw thanked for this post
    Likes welshhuw liked this post
  3. #2
    north east
    ^ Anyone know if this info is the same for the face lift ?
  4. #3
    11 Post(s)
    If you download yourself a handbook, you will be able to check for yourself.
    Vauxhall Product Forum or from the Vauxhall Website
    This cannot be guaranteed though, depending on the year of your car. I would expect variations and changes from year to year.
  5. #4
    Regular Member Jezzy's Avatar
    S.E
    The engine fuse box layout differs by engine - the ones above bare little resemblance to my prefacelift 2.0T.
  6. #5
    Guys my brother needs to locate his car horn relay on hir 52 LS as his horn is constantly on , cheers guys
  7. #6
    Regular Member vmb2722's Avatar
    May 2012
    Blackpool/St Mary's Bay
    6 Post(s)
    Trim : Exclusiv
    Engine : 1.9 CDTi 150
    Quote Originally Posted by armoured farmer View Post
    Trial and error, tell him to start pulling relays out
  8. #7
    Coventry
    Engine : 2.0T
    Word of warning... the above posted REC relay locations do not match at all with those in my late preface (full CAN) 2.0T
  9. #8
    Sep 2011
    Cambs
    Thanks.
    Sent from my iPhone using Tapatalk
  10. #9
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Trying to find main beam fuse for passenger side
  11. #10
    Nov 2012
    cumbernauld
    QO
    Sent from my GT-I9505 using Tapatalk
  1. earth lead locations?
    By victorM in forum Electrical & ICE (including SatNav)
    Last Post: 5th February 2012, 18:15
  2. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  3. info on fuse and relays?
    By hoochydady in forum Electrical & ICE (including SatNav)
    Last Post: 2nd March 2010, 20:51
  4. LED Relays
    By kentish_bloke in forum Electrical & ICE (including SatNav)
    Last Post: 11th January 2010, 09:08
  5. How to do so much with relays and more
    By chrisgettings in forum Electrical & ICE (including SatNav)
    Last Post: 17th November 2006, 13:13
vectra c fuse box
vectra c fuse box diagram
https:www.vectra-c.comforumshowthread.php132437-Pre-face-vec-c-fuse-relays-and-earth-locations
vectra c fuse box layout
vauxhall vectra fuse box layout 2003
where is vectra c starter motor relay located
vectra c fuse list
vauxhall vectra 1.9 cdti fuse layout
fuel pump relay vectra 3.2
vectra c abs fuse locationvectra c starter motor relay locationVauxhall Vectra C Fuse Box Diagramvectra c fusesvectra c fuel pump relay locationvauxhall vectra fuse box layout 2008what is fuse f15 passenger side vectra 03vectra c ecu fusevauxhall vectra fuse box layout 2005vectra c relay diagramfuse box diagram vectra clocation of relay for heated seat vectra cvectra fuel pump relay locationvauxhall vectra fuel pump relay locationfuse box layout for vectra c 08abs fuse vectra c
