Results 1 to 10 of 11
Thread: Vectra 2006 dash problem
    Mar 2011
    Edinburgh
    Default Vectra 2006 dash problem
    Hi every1, I have a 2006 vectra cdti Sri and the dash has stopped working. The rev counter, speedo, fuel gauge, temp etc all doesn't work but the engine management light is on. Even when I turn the car off and leave it and turn it back on its still not working, any1 know what this could be? Is thisa common fault? Any help appreciated cheers
    scottish region
    im sure but dont quote me on it you take the plug out the back of the cluster and plug it back in and it works am sure its a common fault
    Mar 2011
    Edinburgh
    Thanks for the reply do u mean taking out the actual clocks and the connection behind it? How does it come out?
    Full Member Big Sig's Avatar
    It's the abs multi plug under the bonnet, unplug it, clean it and plug it back in. Doesn't always work but easy to do and it's free.
    Mar 2011
    Edinburgh
    Aw ok and would that cause the rev counter speedo etc not to work?
    11 Post(s)
    In short, yes.
    Not always, but if it is the abs plug, then about the only light you'll see in the speedo pod is the emissions light when you first turn the key.
    Full Member
    South West
    Glasgow
    It's either the ABS multi plug or the CIM.
    Mar 2011
    Edinburgh
    whats the CIM?
    11 Post(s)
    Column Interface Module
  1. vectra vxr ,dash problem
    By allyp in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2013, 19:37
  2. At a loss, cclutch bleed problem, vectra C 2006 1.9cdti
    By Imraldis in forum Engine & Drivetrain
    Last Post: 14th October 2012, 18:47
  3. 2006 vectra 1.9cdti starting problem and i=oil leak on start up
    By tomstubbings in forum Engine & Drivetrain
    Last Post: 24th September 2011, 10:01
  4. Dash Light Problem Vectra Facelift
    By holden77 in forum Vectra C / Signum Car Chat
    Last Post: 10th February 2010, 15:46
  5. Car 2006 Problem
    By nick-v2.2 in forum Electrical & ICE (including SatNav)
    Last Post: 1st September 2008, 00:28
