Thread: Cabin Filter
    Full Member
    midlands
    Default Cabin Filter
    How long should a cabin / pollen filter last? Changed the one in my signum last month - went to spray some WD40 to kill the cricket living in my blower motor and the pollen filter is black!
    Good thing is its doing its job but at this rate its going to cost a bomb in cabin and air filters!
    Mar 2007
    GB
    shouldn't be shot that quick, depends on the driving but about 10,000 miles and mine is normally done.
    Diesel? maybe this points to a problem
    Full Member
    midlands
    Quote Originally Posted by Hideous View Post
    No smell or anything - pulls ok for a 120 - mpg crap around town but ace on a run!
    Does it pull in air from the engine?
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Are the drains clear? It may be mould
    Feb 2011
    Selby
    Vauxhall recommend changing them every 12,000 miles, but if you live in an area with a lot of particulate pollution (eg city centres, industrial area, quarries etc) then they could have a shorter life than that.
    The air is pulled from the scuttle area - ie behind the bulkhead, so it's just air that's sucked in at the base of the windscreen (mainly the driver's side where the holes are). Not engine bay air.
    I think I need to actually remove my blower motor completely to have a proper go at the squeaky bearings, as it's still a bit squeaky despite copious quantities of WD40 and 3-in-1 in the top bearing. I suspect it's actually the bottom bearing that's noisy. Ah well, glove box off again I guess...
  1. Astra Cabin Filter
    By Jabbekot in forum General Motoring Chat
    Last Post: 15th January 2012, 09:46
  2. Smell in Cabin....
    By unreal_event_horizon in forum Engine & Drivetrain
    Last Post: 1st February 2011, 00:57
  3. cabin fan problems
    By hughesdog69 in forum Engine & Drivetrain
    Last Post: 28th December 2007, 23:54
  4. Fumes in the Cabin
    By bennyk in forum Diesel Engine related
    Last Post: 11th December 2007, 13:54
  5. cabin noise
    By scott_150cdtisri in forum Bodywork & Interior
    Last Post: 14th February 2007, 00:55
