Results 1 to 3 of 3
Thread: bolt snapped
    Regular Member tappetpaul's Avatar
    Jan 2010
    dundee
    Default bolt snapped
    hi guys what is the easyiest way to remove a bolt with no head???
    story goes:~ i was replacing the flexy joint on my down pipes and on both manifolds i managed to snap a bolt at the bottom on each one whilst trying to remove the down pipes! what would be the easiest way of removing the bolts with out neccesarily having to got to a garage to get this done???
    its kinda a akward spot to get a drill bit into but will if necessary ifthis is my only option
    cheers
    paul
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Oh Oh Mate...Not Good Paul...
    Hope You Get It Sorted
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Best way if the head is completely snapped off then the only real way is to drill I to the shaft o the bolt and use an extractor I have a set of snap on extractors with are reverse flute so knock that in then turn with a spanner it grips in the hole and extracts the bolt
    Other option is to drill it through completely and then re tap a new thread in to it
    Or if you can get onto the other side of the bolt with the threads then either try some mole grips or I would try with 2 nuts screwed on end try to untwist that way or spot weld another bolt to it and use that but I have all the tools unlike most ppl so 1st 2 options would be the best mate
  1. Snapped tensioner bolt, help :(
    By danny2009 in forum Engine & Drivetrain
    Last Post: 29th April 2013, 17:14
  2. Oops!! Snapped the seatbelt bolt!
    By SlowCoach in forum Bodywork & Interior
    Last Post: 24th October 2012, 11:49
  3. Snapped a bolt ,,,,hahaha
    By collyb in forum Engine & Drivetrain
    Last Post: 6th June 2011, 23:53
  4. Snapped Bolt
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2009, 14:06
  5. Snapped Wheel Bolt
    By Brocks in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 10:17
