Thread: Using op-com to get rid of bulb fault warning on 03 Vectra?
    Mar 2011
    Lancs
    Question Using op-com to get rid of bulb fault warning on 03 Vectra?
    A workmate has an error on his Vectra. It's showing on his dash that he has a bulb out, yet he replaced the bulb 4 months ago but this warning light wont ****** off even though no other bulbs are out. I think he said Vaux will charge about £70 for the pleasure.
    Q1: Can this be rectified with op-com?
    Q2: If the answer to the above is yes, then how do you work your way around the op-com program to do this?
    Cheers.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Is your mate aware that if a tail light bulb fails then there is another to do the job, and also if the brake light fails then one of the tail lights bulbs does its job, so from the rear looking at it you could easily get mistaken that there is no fault. Try cleaning all connections and actually take the bulb holders out of the lenses and re check they ALL work.
    Mar 2011
    Lancs
    Thanks i'll pass on the information. I don't know whether he's aware or not.
    Any idea how to cure it using op-com though, assuming everything is A-ok?
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    For Op-Com information..
    You should contact Ilexa as they provide free life-time support to legitimate op-com owners..
    If you have any other Op-Com device, then this cannot be discussed on this forum.
  1. bulb warning
    By dodus in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd May 2012, 17:08
  2. 05 Vectra CDTi - Blown bulb warning light?
    By gmc in forum Electrical & ICE (including SatNav)
    Last Post: 16th September 2010, 21:29
  3. Warning Bulb gone ?
    By Martinlw in forum Electrical & ICE (including SatNav)
    Last Post: 19th March 2010, 01:04
  4. bulb warning lmp
    By petel in forum Vectra C / Signum Car Chat
    Last Post: 27th February 2009, 13:30
  5. Bulb Warning
    By rider in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2006, 19:51
How to get rid of a bulb fault without changing bulb
vauxhall vectra opcom for blown bulbs
