Results 1 to 10 of 24
Thread: park pilot
    Feb 2011
    cheshire
    Default park pilot
    just had car plugged in at garage where my son works,so when i select reverse,it gives one bleep,all 4 sensors are showing ok,reverse lights are on,but not getting any sound when flag the sensors,anyone any ideas,thanks
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Are you sure it's Park Pilot mate? Don't think mine beeps when I put the car in reverse.
    Feb 2011
    cheshire
    Default park pilot
    think so mate,it`s the 1st car i`ve had with park sensors on,so can you tell me please if poss
    Feb 2011
    cheshire
    Default park pilot
    Sep 2010
    6 Post(s)
    Trim : SRI
    I would expect the Park Pilot Sensors to look like the ones in the picture below. The fact that yours has the collar on the outside makes me think it may not be the Vauxhall kit.
    The wiring for Park Pilot should come into the car in the spare wheel-well and should connect to a white connector block with 9 holes but only 8 of them in use.
    It is possible that this has been knocked but I would expect an error to show when put on a code scanner/tech2 etc.
    There should be a control box for these, the Vauxhall Park Pilot control box attached to the side of the Rear Electrical Connector (fusebox in the boot) but to see it you really need to move the trim but this just pulls out.
    Feb 2011
    cheshire
    Default p/p
    ok mate,thanks, i will have a look tomorrow,i spoke to the dealer on saturday who i bought the car off,he said ( oh yeah ) forgot to mention it when he did the handover,it aint working,so this saturday i`ll take it back to him and ask him to sort it.thanks again.
    Sep 2010
    6 Post(s)
    Trim : SRI
    If the dealer didn't mention the fact that they didn't work then make them fix/replace them, if he sold it with Park Pilot on then make sure they fit Park Pilot and not some cheap eBay version.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    As Lee says, those don't look like park pilot sensors mate, they look like Ebay ones. Could be wrong, but they don't look right. Lift the boot floor and look for a white multi plug with a cable coming from the bumper direction (think it's a nine pin plug from memory).
    Also if you check on your rear electrical centre (REC) you should have a black module attached to it for the park pilot that the previously mentioned cable runs to and plugs into.
    Edit: should have read the WHOLE of Lee's post, he's already told you all this lol
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Just noticed this thread when searching for some info
    That is a genuine park pilot kit however it's the genuine retrofit park pilot kit. It still integrates with the car in the same way the factory fit one does
    The sensors are put into the bumper using plastic collars (although whoever fitted that kit fitted the collars the wrong way round.....the cone shaped ones should be at the outside)
    The OP may have fixed this but the aftermarket kit has a quiet speaker normally mounted behind the passenger side rear seat bolster
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    How big are the holes needed for factory PP, anyone any pics of the REC and how it differs from non PP?...
  1. Park Pilot
    By Simon_Fuller in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 11:17
  2. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  3. park pilot
    By andy bo in forum Electrical & ICE (including SatNav)
    Last Post: 9th March 2011, 23:20
  4. Park pilot
    By hairy31 in forum Electrical & ICE (including SatNav)
    Last Post: 25th April 2010, 16:58
  5. park pilot
    By tditony in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2009, 11:02
