Thread: my old trans fluid thought it would be lighter
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default my old trans fluid thought it would be lighter
    This is images of my trans fluid from my auto box witch am having problems with should it be this dark even tho its old? its smells very rank.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Nope it should be a cherry red colour, that looks like it's well past it! A good fluid change or two might sort your problems depending on what they are.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Old & New:
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    the above pictures still has a nice red tint mine dont lol
    my gearbox has gear changing problems.
    guess am gunna need more that 4 ltrs of gearbox oil lol
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    also to mention there was some "sludge" on the end of the drain plug
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I'd change it once, clean the filter (I can't remember if this can be done on the Vec, might have to take the bottom of the sump off), fill up with fresh oil then in 500 miles repeat the process again. That'll give the box a good flush.
    Regular Member Jezzy's Avatar
    S.E
    Maybe someone put engine oil in it....?
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    How many miles has yours done delboy? My motor has done 64k, I asked my local dealers a while back how much to change the autobox oil, they didnt give me a price, they just said it doesnt need doing until 100k miles...
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    mines done 107k its a diesel if that makes a diffrence my deal told me that they wont change it for me as its not a serviceable part lol.
    ermm sorry to sound dump but my haynes dont say much on autos were is sump for filter lol not done much on autos to be fair
    Sodding Typical on Sea
    Over the years I have read about and also carried out many ATF flush / changes. The fluid does get that colour easily in normal running and the gum and sludge then gets into valve bodies and does cause shift issues.
    most important factor is to get exactly the right replacement fluid and get enough for potentially four changes.
    The amount that drains is probably only 1/3 of the total held in the box and torque convertor, so it takes time to get it flushed.
    If you were to drain the sump, measure the amount then refill the same quantity, run for about 20 miles then allow to cool, unless you have asbestos hands!
    Drop this second time, then replace the filter and rebuild.
    Refill once again but this time observe the method to get the level near right and run again maybe 50>100 miles.
    Drop this again when cool, another 100 miles after do a final drop & fill
    This will get you about 85% of the old oil flushed out and will (or should!) transform shift smoothness.
    Derek
  1. Cigarette lighter socket wont work with lighter
    By Aaron1990 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2012, 18:21
  2. Auto trans problems 2.2 52 Vectra
    By phildecadios in forum Introduce yourself.
    Last Post: 6th June 2009, 07:08
  3. You got your ears on Snowman - Tribute to The Trans Am..
    By BigMan in forum The 'Off Topic' room
    Last Post: 14th December 2008, 13:24
  4. HK Ipod trans Vs the rest
    By Trick202 in forum Electrical & ICE (including SatNav)
    Last Post: 31st October 2007, 19:39
  5. The trans-oceanic express!
    By SignumPhil in forum General Chat
    Last Post: 26th September 2006, 16:48
