Results 1 to 10 of 18
Thread: Oil Change - Hot or Cold Engine?...
    Wales
    Default Oil Change - Hot or Cold Engine?...
    I am due an oil change and have been thinking...why bother warming the car up?
    When itís cold all the oil + suspended junk is in the sump, where you want it. This isnít the case with a warm engine.
    Discuss!
    Warming the engine up a bit, nothing too silly, makes the oil thinner so it therefore drains more easily. Stone cold oil won't flow as easily or quickly.
    You simply warm the engine up a bit, then leave it off for 5-10 mins. The oil will have settled back into the sump but still be plenty warm/thin enough.
    Jul 2009
    The Rift, Cardiff
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Ive always got engine up to running temp, usually after a 20 mile journey.
    Then straight on to my ramps and drain.
    Is this wrong, as thinking now when the oil is draining, there is nothing to lubricate the hot engine parts?
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Hot or cold, ive done it both ways
    Quote Originally Posted by Graham View Post
    There will always be a think coating of oil to protect bearings, remember there is no moving parts to lubricate when the engine is switched off anyway. In here lies the reason to buy a good quality oil that helps protect at start up, as that split second before the oil system pressurizes is where the damage is done.
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Yes good point about no moving parts when engine switched off.
    Ive always used vx 10/40semi. Good enough for me and the wifes 12 yr old Corsa.
    May 2008
    Tyneside
    With the engine up to normal temperature there's a chance you'll burn your hand when removing the sump plug. Health and safety and all that.
    Quote Originally Posted by ChrisBilly View Post
    WTF - what SHE said !!!!!!
    Regular Member dv8's Avatar
    Apr 2008
    West Mids
    Vehicle : Veccy C
    Trim : SRI
    Engine : CDTi
    Warm for me.. i found this works best for me.. but after its stood for a good 5mins, let the oil drain down.
  1. Stiff gear change when cold - fluid changed
    By cont1204 in forum Engine & Drivetrain
    Last Post: 18th December 2012, 14:58
  2. Oil Change and now engine running cold?
    By Morzy in forum Engine & Drivetrain
    Last Post: 21st October 2010, 19:28
  3. Stuttering engine when engine is cold
    By chris_sri in forum Engine & Drivetrain
    Last Post: 3rd January 2010, 00:25
  4. Topping up engine oil... engine warm or cold?
    By Quinten in forum Engine & Drivetrain
    Last Post: 15th May 2008, 18:39
  5. Gear change when cold
    By Martyn21 in forum Engine & Drivetrain
    Last Post: 20th November 2006, 10:47
