Results 1 to 5 of 5
Thread: Heated Seat not working
    Jul 2010
    Yorkshire
    Default Heated Seat not working
    Hi,
    My car has been laid up for a year. I've just put it back on the road and the passenger side heated seat has decided to not heat up.
    The switch seems to work, but the seat doesnt get warm.
    Any ideas on where to check please? It was working before I took the car off the road.
    Thanks!
    Aug 2006
    Is a very naughty boy
    Take the fuse out - its in the rear fuse box, the number is in the handbook and measure the resistance through the heat pad from the fuse connections (with the power off) to check its continuity.
    Jul 2010
    Yorkshire
    Well, either I cant use a multi meter, or theres something wrong lol.
    I couldnt get any readings from the meter, it just stayed at 1..
    Regular Member benny's Avatar
    Feb 2006
    dudley
    silly question youve got some one sitting in the seat as it is not heating up .. ? ...
    Mileage : 000
    Try doing the same from the drivers seat, I take it thak works ok. if there is a different reading, then yes it would point to a fault with the seat. I can not see that not using the car would stop the heater from working, what about the connections under the seat are they "sound" and clean.
  1. Replies: 42
    Last Post: 1st April 2012, 16:03
  2. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  3. Heated seat not working
    By amos in forum Insignia car chat
    Last Post: 10th November 2010, 17:14
  4. Drivers heated seat not working - advice?
    By pgilc1 in forum Electrical & ICE (including SatNav)
    Last Post: 4th December 2009, 17:16
  5. Please help, Heated seat stopped working
    By papz in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2009, 08:39
https:www.vectra-c.comforumshowthread.php132334-Heated-Seat-not-working
opel signum heated seats not work site:www.vectra-c.com
vectra c not heated seat site:www.vectra-c.com
