Thread: Additional Lights in Boot - WEIRD problem
    Regular Member NealM's Avatar
    Mar 2007
    Cheshire
    Vehicle : Pre-Facelift
    Trim : LS
    Engine : 1.8 Petrol
    Default Additional Lights in Boot - WEIRD problem
    Hi All
    Having seen the threads on here about fitting extra led's to the boot area I thought I would do this small mod, as the original light is pathetic.
    I bought an illuminating push switch so that I can switch the additional lights on and off independantly of the boot light. And I took the power for this switch (and the LEDs) from the back of the original light . . So that they would also go off automatically on closing the boot (if I ever forgot to turn them off).
    NOW THE "WEIRD" BIT ! ! !
    The LED's and the illumination on the switch that I fitted do NOT go out when I close the boot. . . . . . The original boot light goes out but not the illuminated switch or the LED's ! ! ! !
    I took the earth point for the LED's & illuminated switch from one of the nuts holding the alarm in place.
    Having faffed about a bit (technical expression ) trying different things to solve this problem; I tried moving the earth point . . . When I moved the earth point to the rear of the original boot light THEN the LED's and illuminated light switch go out when the boot is closed.
    SO question is . . . . How can moving the earth point make a difference ? ? ?
    Any thoughts / comments gratefully received because this is really doing my head in ! ! ! ! ! How can moving an earthing point make a difference ? ? ?
    Regular Member ScotsDragon's Avatar
    Aug 2009
    Lost in Time and Space...
    Trim : SRI
    Engine : 1.9 CDTI 150
    Mileage : 50000
    It is a switched earth just like the interior lights,
    The boot light has a constant 12v and the earth is turned On/Off.
    Dunstable
    you need to take the switched -ve / earth feed from the boot light along with the +ve feed
    Mar 2007
    Cheshire
    Trim : LS
    Engine : 1.8 Petrol
    Hey guys thanks for the replies.
    WHY would you have a switched earth ? ? ?
    Quote Originally Posted by Ademusic
    That's what I did in the end mate. . . Just couldn't understand why it made a difference, but now I do . . . Although I don't understand why vauxhall would make a switched -ve , rather than a switched +ve, seems to go against all know convention / logic. ! !
    Jul 2009
    The Rift, Cardiff
    With most cars the door contact switches are fixed to the metal body of the car, so when a door is opened the circuit is earthed. This means you only need to run one wire to each door and the boot. The vec c has micro switches rather than the old type. And its probably safer having less power wires around the car.
  1. Weird problem with heater blower only works with the lights off
    By evhop in forum Electrical & ICE (including SatNav)
    Last Post: 4th November 2012, 22:02
  2. Weird rear lights
    By kdadidog in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 13:22
  3. rear brake lights weird!!!!!!!!!
    By dobby in forum Electrical & ICE (including SatNav)
    Last Post: 30th December 2010, 18:35
  4. weird dash lights wont go off !!!!
    By mikaj in forum Electrical & ICE (including SatNav)
    Last Post: 28th December 2009, 21:03
  5. Additional lights
    By rob mc in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2008, 20:58
boot light swotch on vectra c
