Results 1 to 2 of 2
Thread: 2.2 DTi in-tank fuel pump.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Default 2.2 DTi in-tank fuel pump.
    Guys,
    Can anybody tell me if the tank pump on the 2.2 DTi is actually inside the fuel tank and whether it uses the fuel as its lubricant?
    I know most modern diesels have the pump inside the tank. Its just that I want to know how low I can let my fuel get before filling up. If its a fuel lubricated type, I'll refill when it gets to the 1/4 mark as these pumps can fail prematurely if you regularly let your fuel level go too low.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    no the 2.2 does not have a pump in the tank ......the injector pump is a self scavaging pump .....picks its own supply up
  1. Replies: 19
    Last Post: 30th May 2012, 15:53
  2. fuel pump in tank noisy
    By dbgb25 in forum Engine & Drivetrain
    Last Post: 30th April 2012, 15:00
  3. NEED in tank fuel pump ASAP!!!!
    By bangty 1 in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2010, 16:04
  4. Fuel pressure sensor/fuel pump failure list following Watchdog investigation.
    By happychappy in forum Vectra C / Signum Car Chat
    Last Post: 14th January 2009, 13:18
  5. is there a electic primer pump in tank in 2.0dti
    By dervdoc in forum Engine & Drivetrain
    Last Post: 12th April 2008, 07:42
astra 2.2 dti fuel tank pump
