Likes Likes:  1
Results 1 to 10 of 15
Thread: safeguard warning
    Regular Member Gerdo3's Avatar
    Blantyre
    Default safeguard warning
    this is doing me head in, recently have the above flashing up whenever the ignition is turned on, but... the alarm is working fine as far as i can tell
    any advice?
    thanks
    6 Post(s)
    Get the fault code(s) read out.
    Jun 2006
    Lake District
    Vehicle : Vauxhall Insignia
    Engine : CDTi 160
    Mileage : 53.000
    Dodgy sensor by the screen/rear view can cause this.
    Regular Member VEC-MAN's Avatar
    Nov 2007
    LEICESTERSHIRE
    Have you had the front interior light out ??. I had this as well, I did the light mod years ago and was fine until a couple of months ago. Check 30amp fuse. Check the switch under bonnet just above the air box, mine whet off when i took out the interior to check connections. Funny thing was when I had finished it was still showing warning. Went out in the car later and all was fine and has been since. So not really sure where the problem was. Just happy for it to be gone.
    Blantyre
    Dave: how do I get the fault code?
    mad on vaux/vec man: thanks for the advice will have a look tomorrow & try what you suggested
    thanks for the advice guys, will let u know how i get on
    6 Post(s)
    Quote Originally Posted by Gerdo3 View Post
    Tech2 (or equivalent) fault code reader at a garage.
    Ely, Cambridgeshire
    57 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    As you've got an estate (according to your profile), it could also be a high resistance connection or a break in the rear window sensors or rear heated screen (the alarm uses this as a break detector).
    Check your rear heated screen doesn't have a break in any of the lines anywhere and check the rear window sensors (you need to remove the side supports in the boot to see them.
    You can see the two wires on my passenger side one in this picture (sorry only pic I had to hand).
  8. Likes Dog_Book liked this post
  9. #8
    Jul 2009
    The Rift, Cardiff
    Quote Originally Posted by Ian-Highlander View Post
    Although, if you also keep a young lady in the boot, it might be her trying to escape thats setting off the alarm
  10. #9
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by ChrisBilly View Post
    Yeah, people tend to frown upon that.
    If it is the bars on the windows, I think the stuff you can get to paint on to repair heated windows will work ok. Can't remember what it's called though. Is the siren in the boot plugged in?
  11. #10
    Ely, Cambridgeshire
    57 Post(s)
    Year : 2010
    Oops, I uploaded pictures over the top of some others and accidentally over-wrote my original pic in this thread.
    To avoid confusion for anyone reading this thread in future, the picture above is not the one I originally posted which is here...
  1. Anyone know what a "SAFEGUARD" warning in info display means?
    By andy d in forum Electrical & ICE (including SatNav)
    Last Post: 28th August 2016, 21:00
  2. Flat Battery = Jumping = Warning light = Safeguard
    By HITFACTORY1403 in forum Troubleshooting
    Last Post: 27th June 2012, 18:38
  3. safeguard check warning on dash,why?
    By pogo in forum Vectra C / Signum Car Chat
    Last Post: 4th March 2012, 00:41
  4. Dreaded 'Check Safeguard' warning
    By alcutler in forum Electrical & ICE (including SatNav)
    Last Post: 15th November 2011, 10:32
  5. safeguard
    By exvectra in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2006, 18:41
vectra c safeguard warning
vectra safeguard warning
safeguard warning vectra
