Thread: New fault code found
    Regular Member V5LED's Avatar
    St helens
    Default New fault code found
    Found the following fault code using op com B0082-3A SOD CSD Configuration Fault (Seat Occupied Detection)(Child Seat Deteted)
    anybody got any idea what this means? At the moment the airbag warning light it lit up. Any advise appreciated.
    Regular Member rjw's Avatar
    Oct 2010
    cornwall
    theres a sensor in the front passenger seat that detects a child seat, and automatically deactivates the passenger airbag when it senses it, take it you have no child seat so it will be a sensor fault
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Have a look under the seat, there should be a multi plug, I'd start by checking that's plugged in properly. To be one the safe side disconnect the battery and don't tough anything for 10 mins before you start messing with the plug, its good practice if your messing with any airbag electrics.
    You can see the plug several times in THIS thread HTH.
    St helens
    Quote Originally Posted by rjw View Post
    No child seat fitted. Thought that the child seat detection was optional extra. Is it possible that the leather seats I've just fitted has the sensor in for that and that's why it's playing up?
    St helens
    Sorted, used a post on here. Disconnecting the pressure sensor in the seat from the seat harness all happy now
  1. finally found a solution to the P1112 fault code :-)
    By Casper85 in forum Engine & Drivetrain
    Last Post: 7th December 2012, 14:00
  2. Fault Codes Found
    By fattony in forum Engine & Drivetrain
    Last Post: 11th June 2012, 21:09
  3. Found the fault code but what does it mean
    By Telboy in forum Vectra C / Signum Troubleshooting
    Last Post: 10th July 2011, 19:49
  4. Found fault code but stuck
    By vectra-c1000 in forum Diesel Engine related
    Last Post: 3rd April 2009, 14:29
  5. another fault i found out
    By andy.l in forum Vectra C / Signum Car Chat
    Last Post: 2nd November 2006, 22:35
b0082-3a
vectra c b0082op com select seat occupiedHow to disable seat occupied detection using opcomb0082 opel
