Thread: Wynns EGR Cleaner
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Default Wynns EGR Cleaner
    Anyone used it with success? Guessing it is a similar product to the 10k Boost.
    Bought a tin yesterday but don't have long enough arms or legs to reach the inlet and the accelerator at the same time, will idle speed be OK?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Try searching you might find this
    http://www.vectra-c.com/forum/showthread.php?t=86786
    stockport
    Thumbs down
    Quote Originally Posted by RobW View Post
    Yep,2 cans.One as recommended,the other,straight into the throttle body housing.Just as a passing mention,when I took the big turbo pipe off the throttle body,it was pretty clean inside,so I presume that the first can did what it said on the tin!!!. FELIXX.
    stockport
    Quote Originally Posted by felixx View Post
    By the way,I got the wife to hold the revs steady for me,as,when I tried doing it on tick over there was diesel knock,so beware etc,etc. FELIXX.
    Tain - Easter Ross
    Turbo pipe? I thought it would go in just after the AFM?
    stockport
    stockport
    Thumbs up
    What I did was detach the bottom end of the the big rubber pipe that comes down from the throttle body and sprayed the can in there,(after the turbo),and the second time I detached the pipe where it is connected to the throttle body and sprayed it in there.The effect is the same,it's just that all the can is going into the throttle body/inlet manifold.I did it this way because it is recycled back through the EGR eventually,and anyway,I think the inlet manifold is of prime importance. FELIXX.
    Regular Member Marky's Avatar
    Jun 2006
    North West
    No. Felix did it correct. Its for cleaning the Throttle Body, EGR and Inlet only. It should not be put into the turbo or the intercooler.
    I used a couple of bricks carefully balanced on the throttle. You need to hold the revs at 2k. Then spray it in shorts bursts, otherwise the revs really drop.
  1. Wynns Diesel EGR3 Air Intake & EGR System Cleaner
    By Gazz in forum Engine & Drivetrain
    Last Post: 11th October 2012, 07:46
  2. Wynns EGR Cleaner
    By Governor in forum Diesel Engine related
    Last Post: 3rd February 2012, 22:37
  3. wynns egr cleaner 3.0 v6
    By i5aces in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 22:24
  4. Wynns Diesel Fuel System Cleaner
    By congaman in forum Vectra C / Signum Car Chat
    Last Post: 13th October 2010, 16:50
  5. Wynns EGR3 any different from Carb Cleaner?
    By richardn in forum Engine & Drivetrain
    Last Post: 4th June 2010, 19:29
wynns egr cleaner for vectra
