Results 1 to 10 of 11
Thread: 06 Vectra est 1.9cdti Sri 150 brakes advice pls
    woking
    Default 06 Vectra est 1.9cdti Sri 150 brakes advice pls
    Hi as title says I need some advice on some brakes on my 1.9cdti Sri 150.
    Now I wanted to replace all discs and pads but my local garage just quoted me £315 and that's with 10% discount.
    I think that's alot as it was half that to do my bmw brakes. Am I being cheap or is thAt normal?
    Quote Originally Posted by lgtuk View Post
    thats a rediculously high price
    to purchase pad and discs sets for the front and back would cost about £120 from the dealers
    that leaves them charging you £200 for labour on a job that takes about an hour with a workshop tools
    front kit set part number 93186297 ( 285 mm )
    rear kit set part number 93186300 ( 278 mm )
    hope this helps
    woking
    Sorry maybe being very thick here but how do I use the part numbers? Is it like eurocarparts part numbers?
    http://cgi.ebay.co.uk/VECTRA-C-SRI-C...item5ad7856030
    Have a look at the above link. Im not saying you should buy the stuff but it lets you see the price of the parts. The seller has great feedback as well.
    Regular Member kevcdti's Avatar
    North east
    They are vx numbers mate
    Depending on budget if going with eurocarparts eicher budget and pagid for something better
    But as said its worth comparing the prices with vx
    woking
    Are these cheaper brands I.e. eBay/eurocarpart ok to buy I don't take my car on the track but what's the difference why are they cheaper?
    Sodding Typical on Sea
    These numbers are main dealer numbers for the kits, they are a cross reference for you once they are given to you to ensure they are correct.
    As for ECP simply enter your reg number and the correct kits option sets are presented from the various manufacturers depending on budget you choose the one best suited.
    What you generally find is that the mainline brand mfr, also makes a budget brand which is equally as good for normal use. I tended to go with Eicher and Pagid brands as the "budget price" ones instead of the ATE, Brembo and suchlike at almost double the cost.
    North east
    some may not last as long as the original vx ones,some will give more brake dust then others and some will suffer brake fade under hard constant braking but its all down to personal budget
  1. Upgrading 1.9cdti brakes
    By PeteD in forum Handling & Braking
    Last Post: 21st April 2012, 20:49
  2. 1.9CDTi SRi 150 Rear Brakes!
    By John24 in forum Suspension, Wheels & Brakes
    Last Post: 6th November 2009, 20:25
  3. Advice on vectra 1.9cdti sri purchase
    By raymysterio in forum Vectra C / Signum Car Chat
    Last Post: 24th May 2008, 18:03
  4. 1.9cdti brakes
    By CHRISSMART41 in forum Suspension, Wheels & Brakes
    Last Post: 17th November 2007, 19:06
