Thread: dipstick snapped!
    Feb 2011
    hampshire
    Default dipstick snapped!
    checked my oil today and managed to snap the end off the dipstick!.
    Has this happend to anybody else? is it best to remove sump and fish it out before starting engine?(2.2sxi 05plate). thanks
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    how long is the bit that snapped? can you not use a magnetic screwdriver down the dipstick tube
    Glasgow
    Personally i wouldnt panic about it, there is a gauze over the oil pick up pipe in the sump so it shouldnt pick it up. You could give it an oil change and poke about in the sump with a mechanics extendable magnet and hopefully it should come out on the end of that.
    Feb 2011
    hampshire
    the snapped piece is around 1 inch (its the flat piece of metal on the end of the dipstick) think i will try the magnetic screw driver, thanks for the reply
    Edinburgh
    think to get the sump off you need to take a driveshaft out :s
    Forum Moderator FIL 4822's Avatar
    On a French Carp lake somewhere x
    6 Post(s)
    Vehicle : Insignia VX-line RED Tourer
    Trim : No, over weight!
    Engine : Flux Core Capacitor
    Year : 1 A.D
    Mileage : Rising
    I think the piece you've broken off may be an aluminium alloy so a magnet wouldn't work.
    I stand to be corrected though !
    Feb 2011
    hampshire
    mmm sounds like it could be a job for a mechanic, ive owned the car for just under 3 months hopefully he will sort it, ps glad i bought it though looks and drives nice
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    Quote Originally Posted by byebyeitsagsi View Post
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    How the hell did you do that? If you do go down the magnet route, you can pull the dipstick tube out so you can get better reach or even go in through the drain plug. But as said it could be ally.
  1. Dipstick
    By bigmac in forum Insignia car chat
    Last Post: 2nd July 2012, 21:38
  2. Snapped exhaust manifold/turbo stud snapped in cylinder head!
    By XPCobra in forum Engine & Drivetrain
    Last Post: 7th May 2012, 10:50
  3. Oil Dipstick Help
    By Yohan in forum Engine & Drivetrain
    Last Post: 7th April 2012, 22:04
  4. Reading the dipstick - 1.9 150
    By AlexGSi2000 in forum Vectra C / Signum Car Chat
    Last Post: 16th November 2011, 12:08
  5. HELP!! Dipstick end has broken off
    By spiderrob in forum Engine & Drivetrain
    Last Post: 2nd March 2009, 16:18
snapped my dipstick end on my vauxhall signum help
