Results 1 to 3 of 3
Thread: Fault code p0102 help!!
    Jul 2010
    yorkshire
    Default Fault code p0102 help!!
    well,, i fitted an induction kit few days ago. The engine light has come on so ive done the pedal test, and the code has come up with P0102 Mass or Volume Air Flow Circuit Low Input.
    Could this be that there is oil on the MAF, or have i damaged it when fitting the iduction kit??
    Any help would be much appreciated.
    Regular Member TimTay's Avatar
    Nov 2010
    BRECHIN
    i had a few fault codes come up after fitting my greencotton, but my codes sorted them selves out after a few days and vanished.
    Jul 2010
    yorkshire
    i fitted it last friday so ive had it on now for a good week?? and as the engine light comes on there is hardly any power. ive put the old airbox back in and going to see if it comes on again. if it does, then i knoww the maf is donald ducked.
  1. Fault Code help
    By MiniVauxhall in forum Engine & Drivetrain
    Last Post: 17th May 2012, 10:04
  2. fault code on vec c 1.8 sri please help
    By gavs-sri in forum Engine & Drivetrain
    Last Post: 10th April 2012, 21:52
  3. Fault code
    By bellsjoe in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 22:24
  4. Help with fault code,
    By robwilson69 in forum Suspension, Wheels & Brakes
    Last Post: 13th December 2009, 21:57
  5. Fault Code
    By fattony in forum Engine & Drivetrain
    Last Post: 6th April 2009, 22:24
p0102 vectra
p0102 opel signum
vectrs fault codes p0102
Vectra c p0102
