Thread: CV Joints - Fubar?
    Jan 2010
    York
    Default CV Joints - Fubar?
    A few weeks ago, I had a rumble appear a few weeks after replacing the front tyres.
    Had wheels up, no movement that wasn't supposed to be there, no untoward noises when spinning the wheels (all 4 I might add) and as the noise is no worse on corners I discounted the bearings. I just put it down to the Maxxis V -rated tyres making a row as some guys suggested in my previous thread.
    Well, the car has covered summat like 2000 miles with this noise, and it's getting a tad on my t1ts, so this morning, with a bit of time to myself, I jacked car up and this time, removed the front wheels and oh deary me, I found this on both sides.......
    Could this be the cause of the rumbling?
    It starts about 20mph and totally constant with road speed as opposed to engine speed.
    Is it a hard job to replace the CV joints?
    I have the discs and pads to change at the front, so if possible, I'll do these.
    Not used to this front wheel drive malarkey to be honest!
    exeter
    i would like to know this as mine is leaking ?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    they are the inner cvs you just change boots (rubbers) repack with grease and top up gearbox shaft just pops out when removed from strut
    Jan 2010
    York
    Quote Originally Posted by markj23 View Post
    Cheers for that.
    Repack with grease - got that, but ".........top up gearbox shaft just pops out when removed from strut" ???
    East Midlands
    Quote Originally Posted by PedroMV6 View Post
    Cheers for that.
    He means that when you remove the cv joint which you have to ,to replace the rubber boot you will loose a small amount of oil from the gearbox.
    exeter
    can you top up gear box oil in the level nut hole ?. because the manual tells you to undo the level bolt and then undo another nut high to put the oil in untill it comes out the level hole . so i thought i could just put in that hole first ?
    Jan 2010
    York
    Quote Originally Posted by macdad View Post
    Aah - cheers for that!
    Looking at the price of CV joint kits on eBay, I might as well replace the whole lot, both sides for peace of mind.
    Anyone think this would be the cause of the rumble?
    Sep 2010
    Plymouth
    Engine : 1.9 CDTi 150
    Year : 06
    Mileage : 250,000
    I have been told by my garage that both of my inboard joints have excessive wear, most likely due to someone in the past allowing them to run dry when the boot had failed
    Jan 2010
    York
    Found out that refurbished shafts are about £250, obviously plus fitting.
    Yee-ouch!!!
    Jan 2010
    York
    Biting the bullet - refurbed driveshafts being fitted today - £400-ish, but at least both ends are new and sorted for a long time to come!
  1. Inner CV Joints
    By Gmc12 in forum Vectra C / Signum Car Chat
    Last Post: 1st January 2013, 17:22
  2. bad joints on pcb
    By hippo in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2011, 08:31
  3. Air con condensor fubar
    By Bigtee in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2011, 10:34
  4. Inner Tie Rod Joints
    By Electricdave in forum Suspension, Wheels & Brakes
    Last Post: 8th June 2010, 19:29
  5. cv joints compatability
    By dan the man in forum Suspension, Wheels & Brakes
    Last Post: 21st July 2009, 21:09
