Results 1 to 10 of 11
Thread: Fluid on the rear brake calliper
    Feb 2011
    bedfordshire
    Eek Fluid on the rear brake calliper
    I recently changed the rear n/s brake calliper (with help from this site) and changed both sets of brake pads on the rear. All seems fine, the cars stops fine and the correct level is in the reservoir. The only niggling thing is I'm finding what seem's to be a small fluid (leak?) on the bolt which connects the hydraulic pipe to the calliper. I have made sure it is on tight, which it is, and the bleed nipple area is dry. Any ideas?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Is there not a small copper washer on one or either side of the banjo bolt connector? Maybe this is where the leak is.
    Feb 2011
    bedfordshire
    There is a washer between the bolt head and the square connector but I can't tell if its copper or not. Do you think the washer may just need to be renewed then?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    May do, got to be worth look into as if there is a leak air will no doubt find its way into the braking system. Maybe there's just a small piece of crud preventing a proper seal.
    Feb 2011
    bedfordshire
    Thanks DasArab. As soon as I get the wheel bolts sorted I'll pull it off, I'll clean it up and maybe renew the washer and see where I am from there.
    Sodding Typical on Sea
    The copper washers are the most likely source of leak as they are generally one way items and for the cost of them it is worth doing, but it is one of these things that you never pick up on till it does leak!
    Feb 2011
    bedfordshire
    Next time I'll replace the washer just incase
    Do you know what size it is? I would like to be able to buy one before I take it apart for replacing.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    There should be two seal rings either side of hose banjo done up to 40nm
    Feb 2011
    bedfordshire
    So there should be a sealing copper washer on both sides of the banjo connector? I think I have only the one on mine so that would explain the small leak. Do you know what inner and outer diameter the seals are?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Sadly not but being brake hydraulics i wouldn't take a chance and get
    new ones from a dealer then you know you have the coorect ones
    and surely they cant be much
  1. Is the seal for the piston on the rear brake calliper glued on ?
    By siadwel in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2012, 18:47
  2. brake calliper carrier
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 16th June 2011, 18:44
  3. yellow brake calliper brake set
    By The Gas Man in forum Parts for sale
    Last Post: 22nd July 2010, 22:41
  4. Brake Calliper Help?
    By Digital_kid in forum Suspension, Wheels & Brakes
    Last Post: 17th July 2007, 11:31
