Thread: Remap question.
    Regular Member StephNET's Avatar
    Wiltshire
    Question Remap question.
    I know from reading other posts on here that a remap screws up the instant consumption figures reported by the trip computer. Does the projected range remain accurate, or does this become false as well? This is on a 1.9 CDTi.
    Thanks.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The computer is inaccurate anyway - the BC once told me that from a full tank I used 10Gal = 45.40ltres. When I filled it upto the same point (pump clicked in fuel filler), the pump said 52ltres.
    To my knowledge a remap shouldn't affect the onboard computer as the ECU knows what the remap is doing unlike a tuning box which 'tricks' the ECU.
    Gazza4
    West
    as above, remaps do not fool the obc like the tuning box
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I am getting single figures in my instant display when i pull away with my remap on,and an average of 37 mpg on a 25 mile dual carriagway/a road run,with my tuning box on i was getting 60 mpg average on the computer,but still only getting 38 mpg actual
    Regular Member GTS's Avatar
    Oct 2010
    Poland
    Mine (cdti 120) after remapping shows less fuel consumtion and bigger ranges. hope this is true. Unless I believe it, I'm satisfied
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Why the instant Mpg Computer displays an incorrect figure....
    Intercepting the Rail Pressure sensor is the key to Tuning Boxes. The ECU/engine will control the pressure, and it uses its sensor to confirm this. This figure is vital for the ECU to know the fuel quantity.
    Adding a resistor into this sensor circuit passes the wrong information to the ECU. What was 1500bar is now reported as 1400bar, so the ECU will activate the high pressure injection pump to raise the pressure by 100bar above the sensor value. The extra pressure will force more diesel through the open injector, and as mentioned, for a diesel, more fuel = more power.
    Basic Diesel Theory
    Taken form Here
    http://www.endtuning.com/dieseltuningboxes.html
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by DeanF View Post
    Well you answered your own question dean:
    Basic Diesel Theory
    Taken form Here
    The ECU effectively thinks that the fuel rail is at a lower pressure hence raises fuel rail pressure which means more fuel. For example take a standard CDTI at 1500bar is pushing 10units of fuel per second. If the the ECU is duped into thinking that this is happening at 1400bar, then when it compensates (which is why it increases the work of the high pressure fuel pump), at 1500bar there is now 10.72units of fuel per second. Also fuel rail pressure is maintained regardless of engine speed too afaik. All the box does is make the ECU think there is less fuel being pumped into the engine.
    However this is happening at a lower Air to fuel ratio now as well - hence the black smoke. This can lead to possibly unburned fuel.
    Remaps will change the turbo settings too as I understand hence more and more fuel - maintaining roughly the same air to fuel ratio. At idle deisels have an air to fuel ratio of about 40:1, then by the time it gets to full load/maximum horse power it has dropped to about 18:1.
    Gazza4
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    Good article Dean, very interesting.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Quote Originally Posted by Aikon58 View Post
    Remapping makes no difference to the instant mpg displayed if you put your foot down fully. On my old 2.0T it was 7.1 mpg, and on my diesel 11.1 mpg.
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    Quote Originally Posted by GTS View Post
    That is certainly possible, given that you don't make too much use of the extra power/torque at your disposal.
  1. hi all remap question
    By matt450 in forum Diesel Engine related
    Last Post: 11th October 2012, 19:16
  2. Remap question?/
    By Governor in forum East (RO - WhiskyNo7, ARO - Plasma)
    Last Post: 6th June 2012, 13:48
  3. remap question???
    By azz man in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2010, 22:34
  4. remap question
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2008, 14:46
  5. Question about BSR Remap
    By Turbo Signum in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2007, 20:08
