Results 1 to 10 of 25
Thread: vectra cdti sri fuel filter change????
    Regular Member Mads's Avatar
    Ipswich,.UK
    Default vectra cdti sri fuel filter change????
    I tried to change the fuel filter on the weekend but didnt get very far, i can get the fuel lines off easy enough and i have a haynes manual too but i can not get it out of the canister????? the manual says to get a screw driver and put it down the back on the right hand side to release but i cant see where it is to release it, i knoiw some people say to get new clips has these sometimes break but i need to know where exactly you need to put the screw driver and what you need to do to get it out please as the pic in the book is not that clear??
    many thanks
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    I don,t take the fuel filter canister out of the carrier, just take the bolt out of the middle of the fuel filter lid. Be careful when replace the lid as not to dislogde the new rubber seal, it p****s diesel out everywhere, when it starts....
    Ipswich,.UK
    Quote Originally Posted by omega63 View Post
    maybe im not looking hard enough but i didnt see the bolt in the middle, i know it twists off so is there a bolt too then?? also i wanted to drain it to get rid of any water content and i know the screw for that is on the bottom, did you get to yours ok?? have the car and spanner light up so hoping this may be the reason before the egr and boost valve
    Jul 2010
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by Mads View Post
    In the centre of the lid there is a "Torx" head bolt, unscrew this and lift off the lid gently, it is easier if you remove the fuel lines. Replace the filter and rubber seal and clean out the lower fuel canister bowl. Bolt down the lid without over tightening, and begin to start the engine in 10 sec. bursts this will avoid burning out the starter motor. It should begin to start after the 3 > 4 attempt, and dont forget to reconnect the wire/connecter for the fuel heater in the lid or the car/spanner light will come on....
    Ipswich,.UK
    is the torx head bolt next to the connector on top for the fuel heater??? as my lid has the grooves on the outside which apparently you need a tool for to unscrew it but you can make something similar.
    Jul 2010
    Mileage : 126,000
    Thumbs up
    My friend as the 1.9cdti 150, is a 55 reg. is car/spanner light was on at the instrument panel, this was because the wire/connector was not connected at the fuel filter. The wire had fallen down the bulkhead in the engine compartment on top of the steering reservoir/pump. Mines a 3.0L cdti V6 i think there the same the fuel filters or very similar, check this wire/connector firstly.....
    Ipswich,.UK
    thanks omega63 i have a 1.9 cdti sri 55 plate, i will check this tomorrow
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    I thought the 1.9 was completely different? Don't they use a special fuel filter?
    West
    both use different filters, same principle mind
    Ipswich,.UK
    sorry.... i know the fuel heater wires are connected as i took them out and put them back in on my first attempt, maybe i will try to make a tool to unscrew the lid and change it that way without taking the canister out.
  1. How to change the fuel filter on 1.9 CDTi??
    By mpc in forum Vectra C / Signum Car Chat
    Last Post: 22nd March 2012, 13:11
  2. 04 vectra 1.9 fuel filter change
    By mick232 in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2010, 18:22
  3. 1.9 CDTI (150) fuel filter change
    By klesniks in forum Vectra C / Signum Car Chat
    Last Post: 1st November 2009, 13:25
  4. oil filter change 1.9 cdti vectra c
    By haggispie in forum Vectra C / Signum Car Chat
    Last Post: 18th June 2009, 19:37
  5. Oil and fuel filter Change on a CDTi 3.0 V6
    By pwjolly in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2008, 14:53
how to change fuel filter on vectra c 3.0
vectra c fuel filter change
vauxhall vectra fuel filter location
prime fuel filter on v6 cdti
https:www.vectra-c.comforumshowthread.php132140-vectra-cdti-sri-fuel-filter-changepage2
remove fuel filter on vectra sri
vectra c fuel filter removalhow to change a air filter on my vauxhall vectra hatchback 1.9 cdtihow to remove the lift pump on vauxhall signum 1.9vectra c fuel filter change www.vectra-c.comvectra 1.9 air in fuehow to remove fuel hoses from ftel oump casing on vectra c 3.0 v6how to remove hoses off fuel filter casing on a vectra c 3.0 v6pics of fuel filter location on vectra c 2006vectra v6 fuel lift pumphow to change heater filter on a vectra c cdtivectra c fuel filtervectra fuel filtervauxhall vectra cdti sri fuel filter housinghow many fuel filters vectrahow to change fuel filter on vaxhall vectravectra v6 cdti air filter replacementremove fuel filter vectra 2008vectra 3.0cdti air in fuel filter housing
