Results 1 to 10 of 13
Thread: hmmm catalyst converter
    Regular Member Kamikazy's Avatar
    Feb 2006
    United Arab Emirates
    Default hmmm catalyst converter
    Iím looking forward to remove the catalyst converter from my 2.2 vectra
    Do you think it will work or I will have some problems?
    Any idea ?
    Regular Member Daycall automotive's Avatar
    Dec 2005
    essex
    theres alot of mixed reactions on this subject from what ive seen (work in a local dealers) it does seam to help the exhaust flow alot better, but one car we had in that removed the cat had the light come up on the dash, it might have been just an isolated thing though
    it will also fail the CAT test when it comes to MOT time. if it ain't there it won't work.
    It's also in the big can behind the exhaust manifold, so to remove it will involve cutting and welding the box. you can't just pop a pipe in.
    it's also against construction and use regs as they now require all cars to be fitted with a Cat.
    what will you gain..little.
    Just probs for the future
    Regular Member benny's Avatar
    Feb 2006
    dudley
    its part of the manifold on the later 2.2 engine also the man light will be on constantly due to there being two o2 sensors one before and one after to check the cat is there and working .;..........
    Feb 2006
    From where I can find a sport cat ?
    any good idea for more BHP
    Melbourne, Australia
    I'm guessing that any performance improvement made by removing the catalytic converter would be outweighed by having the engine run in limp-home mode. As benny said, the post-cat oxygen sensor will detect that the cat's not doing it's job.
    Feb 2006
    aha ....
    can i play with the oxygen sensor & chang the sensor reading ?
    not really, it's a floating variable of the lambda measurement, so you can't 'fix' it at any one reading.
    more power?? air filter, exhaust, iriduim plugs, Performance cams, Cylinder head work, Re-map, Supercharger?
    Have a look at www.courtneaysport.co.uk for ideas
    Feb 2006
    the link is not working ^^!
    i past it @ google.com
    Did you mean: courtenaysport.co.uk
    http://www.courtenaysport.co.uk/
    Anyway thanks a lot ^^
    realy you helped me alot ^^
    naw i can make more BHP for my vectra
    Regular Member ion's Avatar
    walsall
    Off topic, I'll be coming to UAE early next year Kamikazy, where abouts are you?
    I'll be travelling to Dubai & Abu Dhabi.
  1. P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    By winty234 in forum Engine & Drivetrain
    Last Post: 8th May 2016, 13:33
  2. Catalyst system efficiency below threshold bank 1 not present
    By tomo41 in forum Engine & Drivetrain
    Last Post: 11th July 2011, 23:00
  3. PO422 catalyst efficency thresold 1 or somat
    Last Post: 19th June 2011, 20:49
  4. Catalyst help
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2010, 18:03
  5. Hmmm I wonder
    By corsa_si in forum Styling
    Last Post: 25th May 2009, 18:06
