Results 1 to 10 of 16
Thread: boot light leds
    Sep 2009
    Glasgow
    Default boot light leds
    Have done the mod with led strips either side of boot a while ago but still wasn't pleased with the light, so tonight with one spare strip added a third led strip in middle of parcel tray along the middle rigged edge stuck on with double sided tape and WOW it is lit up well now. will post some pics later.
    Regular Member moorlander's Avatar
    Apr 2008
    Staffordshire
    look forward to the pics!
    VIP-Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    Thought of doing that with mine but seeing as I often have the seats down and parcelshelf removed (daughters horse feed and wood shavings), I couldn't be bothered with the constant connecting and dis-connecting
    Be nice to see what it looks like though
    Already replaced:-
    Alternator,
    Drilled/Grooved Discs & Pads, Eibach Springs, EGR Valve, 50W HID's 6000k, K&N Panel Filter, LED footwell & boot lights
    Liverpool
    Quote Originally Posted by moorlander View Post
    I have a strip either side and mine is fine
    Hanging Heaton / Batley
    18 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Quote Originally Posted by Damo77 View Post
    I screwed a ground kit neon tube to the parcel shelf in my astra, and put a connector on one end. was easy to then disconnect when seats where down.
    Regular Member bulletproofpanda's Avatar
    Sep 2010
    Nottingham
    Have wired mine from the existing light in the boot and tucked the wires behind the plastic panel parallel to the bumper and behind the back of the side compartments.... Works really well as like you Im taking the parcel shelf in and out all the time.
    If there is any interest Ill post some photos
    Apr 2008
    Staffordshire
    Quote Originally Posted by bulletproofpanda View Post
    If you have time it would be appreciated
    Year : 55
    Mileage : 92,000
    Have done exactly the same mate on mine but couldn't be bothered with the agro of disconnecting the wires all the time if I had a third strip along the base of the parcel shelf itself.
    Quite happy with the amount of light with just the two either side but I may be swayed into fitting another to the parcelshelf
    Many thanks for the offer though
    Already replaced:-
    Alternator,
    Sep 2009
    Glasgow
    here is the pic looks good and plenty of light.
    Apr 2008
    Staffordshire
    you are right! - looks good & plenty of light
  1. Second boot light and leds
    By sriandy in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2012, 07:25
  2. fitted leds in boot (quick pics)
    By scottwales in forum Styling
    Last Post: 3rd July 2012, 22:31
  3. Changed my Boot LEDs...
    By davedrinks in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2012, 19:25
  4. DRL's / boot leds
    By jays_225 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2011, 15:50
  5. Boot LEDs fitted...
    By davedrinks in forum ICE Gallery
    Last Post: 25th February 2011, 21:39
