Page 1 of 5 123 ... LastLast
Results 1 to 10 of 49
Thread: 72k on 1.9cdti 150...should I get timing belt done?
    Regular Member marky2027's Avatar
    Northumberland
    Default 72k on 1.9cdti 150...should I get timing belt done?
    I'm in a proper dilemna here. My vec has 72k on now and I keep thinking should I have the timing belt done? I've already had loads go wrong with the car (inlet manifold, EGR, alternator) so I'm not the luckiest!! I'm only keeping the car for about another 18 months so don't really want to be spending megabucks on it. I have AA breakdown repair cover which will pay up to £500 for a repair. This has already been worth it's £75 per year when they paid out for the inlet manifold!! This would go some way towards cost if the worst happened. I know this is not by any means the best logic to employ
    If I do get it done can anyone in the north east recommend anyone?? It takes me long enough to decide where to take it to get service done. Should I get the water pump done at the same time? If I decided not to get it done and it went does this totally wreck the engine?? How much would I be looking at if it went?
    The car is 2006 (56 plate)
    Aug 2010
    Leeds
    You don't say how old your car is but with your luck id say . Yes.!!
    Northumberland
    Cheers for pointing the age thing out...just updated post. Its a 2006
    scottish region
    sure it is recommended every 60k
    Northumberland
    No mate 100k definitely
    Regular Member badback's Avatar
    Runcorn
    Mine was done at 65,000 and the water pump was on it's last legs, not much longer and it would have seized.
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    And if your belt dont go your pump will seize and do the belt anyway
    Sodding Typical on Sea
    Quote Originally Posted by marky2027 View Post
    It is in the handbook for 100K intervals but your thinking is very sound as I plan on doing mine with waterpump at your mileage point myself as I think 100K is just too far
    Northumberland
    Roughly how much for timing belt and water pump to be done then?? How many hours would you say?
    Liverpool
    100k in handbook
    i am getting mine done around 60K
    so i'd say yes get yours done asap
  1. anyway to do the timing belt without timing tool
    Last Post: 15th December 2012, 18:47
  2. 1.9CDTi Broken Timing Belt at 69k Miles!!!
    By Vectra-sceptic in forum Engine & Drivetrain
    Last Post: 24th September 2010, 15:16
  3. 1.9cdti (150) timing belt change £210 is this ok?
    By kirkyoke in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2009, 22:36
  4. Timing belt etc
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2009, 11:33
  5. Timing belt?
    Last Post: 27th December 2007, 22:50
