Results 1 to 10 of 14
Thread: smoky 1.9cdti particulate filter?
    Regular Member fireblade's Avatar
    Feb 2006
    at home
    Default smoky 1.9cdti particulate filter?
    I have had a box on mine since jan 06 (cr1 then powerclick green) they both worked ok apart from bringing on warning light with cr1 hence change to poweerclick which seemed ok on standard setting but in the last minth or so the smoking has got a lot worse to the point that if i boot it now it puts out a smoke field behind me
    I turned it down below standard(12oclock position) and it brought warning light back on,and still smoked with box off it does not smoke,Andrew at dtuk doesn't know what it could be, I tried box on another cdti today and its smoking was nowhere near as bad
    Is the particulate filter self cleaning ? if not has anyone replaced one?
    anyone else had a problem with very bad smoke after running a box for a while?
    mine is 1.9cdti 150 05 spec full can bus
    Regular Member The Doc's Avatar
    'Norf Yorks.
    Auto or manual and estate or saloon?
    Feb 2006
    at home
    car is a sri 1.9 cdti 150 hatchback manual
    Did the hatchback pre-facelift come with a particle filter? A particle filter is to stop the smoking isn't it?
    'Norf Yorks.
    Not unless it was an auto Alex.
    Yes it is. Tis **** tho
    Regular Member Ian's Avatar
    York
    havent a couple of others had this issue, Armoured Farmer and Harry iirc?
    Quote Originally Posted by CDTi
    Got yer, cheers John.
    Yours isn't an Auto is it FB?
    Quote Originally Posted by Ian
    I think they have Ian, but there's are the 3.0 V6 CDTi. This is the first 1.9 I've heard of that's smoking excessively.
    Feb 2006
    at home
    No mine is a manual AJA but smoking has got to the point that I might remove the powerclick box as it is that bad, but on other car it is ok it used to be ok but is geting worse its getting very embarrising
    Simple advice..
    Take the box off....
    While it's generating too much smoke you'll be attracting the attention of the boys in blue.. They will stop you for excessive smoking it's it's bad enough to obsure vision of other drivers.
    Leave the box off for a couple of weeks and see if the excess smoke dies back. If it doesn't then there is somthing amiss, and take it to a dealer to get them to have a look..don't forget to remove the common rail harness.
    Feb 2006
    at home
    When I take box off it stops smoking(well as much as a diesel can) and looks like standard amounts of smoke , ran with it off for a week as soon as box went back it started to smoke again, yet the box does not cause other cars to smoke when I fitted it to them so it must be something on my car
    Only problem with leaving it off is that I am used to the power/torque as it is now when the box is off it feels quite flat in the mid-range
  1. Replies: 6
    Last Post: 9th June 2012, 10:38
  2. Diesel Particulate Filter
    By bafoo in forum Vectra C / Signum Car Chat
    Last Post: 13th January 2011, 18:06
  3. Diesel Particulate Filter Re-gen
    By RobertHayman in forum Engine & Drivetrain
    Last Post: 16th November 2010, 23:47
  4. Diesel Particulate Filter 1.9CDTI temp/permanent fix
    By Drew in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 15:15
  5. Diesel Particulate Filter or not??
    By Drew in forum Engine & Drivetrain
    Last Post: 26th January 2009, 09:32
vectra 1.9 cdti particulate filter
