Results 1 to 5 of 5
Thread: vectra cdti - Clutch thudding when engaging or disengaging
    NI
    Default vectra cdti - Clutch thudding when engaging or disengaging
    i have a 150sri vectra with 45k on it, in last day or two its starting a small thudding noise/feel when engaging the clutch to change gear or depressing it again to disengage a gear... no rattle or knocking type noises associated with it.... anyone come across this or any ideas???
    Slightly worrying given the DMF issues..!
    Stuart
    BULFORD
    Mine is in the garage with the same signs and symptoms mate, but i have a DMFchange at 34k and its only on 42k now so in 8k's DMF again we will soon see!!!!!
    Regular Member wingz123's Avatar
    Mar 2011
    M4 Junc 12
    Hi mate,
    I have had this....I have just posted a thread titled - 'Clutch in...have to be hercules to put in gear'....
    I'm flabagasted and not sure what to do....mine was thudding before this happened..
    thanks,
    Mar 2009
    morecambe
    54 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    if it is the dmf and you have no warranty left i hope you have a healthy bank account
    Mar 2011
    M4 Junc 12
    what does the dmf do?
    what's required to change?
    thanks,
  1. vectra cdti noise on clutch
    By hitcho in forum Engine & Drivetrain
    Last Post: 11th July 2011, 00:01
  2. High Clutch Vectra 1.9 CDTI
    By nishaal in forum Engine & Drivetrain
    Last Post: 16th June 2008, 17:44
  3. Vectra Cdti 1.9 Clutch Judder
    By CHRISSMART41 in forum Engine & Drivetrain
    Last Post: 14th October 2007, 11:15
noise when engaging clutch vectra 1.9cdti 2007
