Thread: airbox
    Feb 2011
    Mansfield, Nottinghamshire
    Default airbox
    hi all,
    I read somewhere the other day that something can be removed from under the airfilter and this makes the car abit more speedy?
    Is this correct?
    If so how do i go about doing it?
    Mark
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    search for airbox mod in search box
    it does not work but sounds like its going faster
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Not 100% correct
    If you open the air filter housing, you will see in the bottom section a removeable section about 100mm x 50mm that covers the top of the intake from outside. Many of us remove this as while it remains in place you will see only one part of a normal filter gets dirty.... thus showing airflow is restricted.
    No-one has any definitive prooof if there is any benefit (other than improved airflow) or any problems caused by removal of this section, but many diesel onwers seem to think a flat spot is improved.
    All down to personal choice.
    Aug 2010
    Luton
    if it worked some one would post up proof !!
    Regular Member jatint's Avatar
    Kilmarnock
    its not rocket science to know if you have poor air flow then you loose power, de-restricting air flow does help a little in this case, i personally have a 1.9 cdti 150 sri and i did notice an improvement but that was because i also fitted a K&N flat pannel filter and de-restricted at same time
    scottish region
    i fitted k and n first and noticed a diffrence then found out about airbox mod and done that and what a diffrence the more air the better
    Barrow In Furness, Cumbria
    No difference noticed in my 1.8 SRi.
    Feb 2011
    thanks for the replys. I have the 1.8. i may give it a try..
    cheers
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    I also removed the trunk section and replaced the filter element with a K&N panel filter. To me the 3.2 seems less hesitant when pulling away (it will pull off in 2nd with low revs now without a problem) and it's still averaging in excess of 28mpg mixed.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    I noticed a difference in my z18xe...car just feels more nippy. Even my mrs. noticed as a passenger. This is more than just placebo. I don't know if the car is any faster, in fact I very much doubt it is, but it just seems to respond quicker to the pedal. Before you had to get the ge ars perfect when pulling away at lights, now its much better. I disconnected battery when I did mine to reset computer, this makes ita bit rough at first.
  1. Airbox mod.....part deux!!! (rip off of VXR280 airbox mod)
    By paul_sri150 in forum Diesel Engine related
    Last Post: 30th January 2012, 22:50
  2. Airbox Mod!!
    By R-ford_Vec_C in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2010, 14:15
  3. airbox mod
    By andy_hare in forum Vectra C / Signum Car Chat
    Last Post: 10th January 2010, 14:29
  4. Airbox mod(But Why)
    By stanian in forum Petrol Engine related
    Last Post: 7th May 2009, 09:49
  5. Help with the airbox mod?
    By strothrc in forum Diesel Engine related
    Last Post: 9th April 2009, 15:10
