View Poll Results: Bilstein & Eibach or Supersport
Voters
9. You may not vote on this poll
  • Bilstein B4 shocks & Eibach springs
    5 55.56%
  • Supersport kit, (matched springs and shocks)
    4 44.44%
Thread: Bilstein or Supersport
    Regular Member themarbleman's Avatar
    sussex
    Default Bilstein or Supersport
    As the title says.
    I'm just about to order new shocks and springs from LMF.
    Do i go for Bilstein shocks & Eibach springs or
    Supersport kit ?
    All comments welcome.
    Regular Member Kev_G's Avatar
    Jul 2009
    C:\Uk\Chester_North West
    had Bilsteins on every car ive owned and always been perfect
    Full Member tubby's Avatar
    May 2007
    Norwich
    Vehicle : Vectra sri
    Engine : 2.2 z22se
    I've got supersport kit no complaints!!
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    I have bilsten dampers and supersport springs
    and still loving it
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Insignia elite tourer vxline biturbo
    Trim : Elite vxline
    Engine : 2.0 biturbo
    Mileage : 80000
    i had b4 and lowered suspension on and ok but they std shocks so can bottom out.. then did the supersport kit loads better as shorter dampers to fit lowered springs deffo best of the 2 kits.
    sold them on last yr as now got B6 shocks and H&R springs now loads loads better than other 2 but should be as price
    Regular Member Marcosuk's Avatar
    Fife
    Im running the supersport 45/40 mm drop & have had no probs so far.. Apart from high kerbs sometimes
    Feb 2011
    Norwich
    confused Monroe shocks
    Hi all, this is the 1st time that I have used a forum. I have a 07 Signum 3.0 V6 cdti. I have just put a pair of Monroe STD shocks on the rear. £67 instead nearly £500 for the Vx genuine ones !! 20mm longer but can't see any difference in the car height ! The ride is a bit firmer and holds the corners a bit tighter!! So far so good. But I had a n/s/f wheel bearing fitted at the same time. But the new bearing was faulty ( I was told it was from a bad batch) ABS sensor faulty (open Circuit) When the faulty one was removed (800 miles and 10 days later the grease was oozing out all over sensor!! New Bearing hub fitted, ABS light out, all is well again !! But the ABS does not work like it should ?? when breaking on dry good roads ABS cuts in for 2 seconds and then ok. Could this be any thing to do with the rear Monroe Shocks as I have been told by my fitter who spoke to Vauxhall on the phone ?????? I hope somebody can HELP ?????
  1. Supersport Shocks x4
    By damian s in forum Parts for sale
    Last Post: 27th December 2009, 00:48
  2. Supersport 45/45 kit
    Last Post: 8th December 2009, 23:35
  3. supersport suspension from l m f
    By wrayballs10 in forum Handling & Braking
    Last Post: 3rd June 2009, 00:32
  4. supersport very cheap
    By kaspers in forum Handling & Braking
    Last Post: 7th March 2009, 11:00
  5. supersport suspension lmf!!!!!
    By damadom in forum Handling & Braking
    Last Post: 24th February 2009, 19:57
