Thread: Front wheel bearing sensor problem
    N.Ireland
    Default Front wheel bearing sensor problem
    I got fitted a new front wheel bearing,the first one that was fitted the ABS warning light wouldn,t turn off so I got a new one thinking the first one was faulty ?I got good advice from a second mechanic saying the light should go out when a new one is fitted.The second one the ABS light went off at first then after driving around a bit the warning lights came on,does anybody know what's going on.cheers
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    i had to change the front hub/sensor on my dads vectra and trying to get the plug to actually connect on the block as a bit of a pain, ide check there first if i was you, make sure it is actually making contact and that the contacts arnt dirty or damaged
    N.Ireland
    Quote Originally Posted by vxpenfold View Post
    thanks, I will check the connections
    Regular Member RobW's Avatar
    Tain - Easter Ross
    I recently fitted a new hub - damaged the ABS/TC wires when I was changing the brakes so had the warning lights on permanently.
    New hub and they went off straight away. There's two types of hub for the Vectra, one with IDS and one without - did you get the right one?
    N.Ireland
    Quote Originally Posted by RobW View Post
    I did get the right one because they have two different types of connections,one with a rectangle shape 3 pins i think and the other (mine)has the oval shape 2 pins,if I had the wrong one it wouldn,t connect at all.cheers
    Tain - Easter Ross
    Ah, I didn't know they had different connections.
    Have you had the car tech2'd to see if there is a description of the fault?
    N.Ireland
    The mechanic has a snap on diagnostic reader that turns off the codes for him,i;ll get back to him tomorrow and see what he says.
    N.Ireland
    I went and drove the car there and the lights went out,there must be a bad connection in the new ones.
  1. Possible wheel bearing problem
    By beethamwest in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 15:45
  2. vectra c front bearing and abs sensor
    By luckyjohn99 in forum Suspension, Wheels & Brakes
    Last Post: 4th August 2009, 08:16
  3. Possible wheel bearing problem?
    By Auto-Brite in forum Handling & Braking
    Last Post: 20th September 2007, 17:21
