Thread: Sidelight Wiring Pin
    Devon
    Default Sidelight Wiring Pin
    I'm fitting DRL's and am wiring them into the sidelights.
    Question is does anyone know which pin of the headlamp wiring plug is actually for the sidelights?
    When I power the sidelights up only, my multi meter actually shows voltage to two of the pins, but I was expeciting to see voltage to only one so I'm confused. One pin shows 14v and the other 24v.
    Anyone have any ideas?
    West Yorkshire
    Surely drl's want wiring to ignition live? Otherwise they'll just be extra sidelights ..
    Oct 2007
    Shropshire
    How do you have 24v in a 12v car? I don't think the voltage is stepped up anywhere? Are you sure it is not 2.4V?
    Devon
    Quote Originally Posted by mucklestone View Post
    Maybe - I'm not too good with electrics, but if the 24v is actaully 2.4v then the 14v on the other pin would be 1.4v.
    I'm fitting the Philips 5 LED DRL's - these need wiring into the sidelight so they auto swith off when the sidelights are switched on. The other cables are connected directly to the pos and neg terminals of the battery.
    West Yorkshire
    Aha, clever stuff.
  1. LED sidelight trial
    By Derek Mc in forum Styling
    Last Post: 21st January 2013, 15:17
  2. best sidelight bulbs
    By montyfert in forum Electrical & ICE (including SatNav)
    Last Post: 17th April 2012, 21:38
  3. LED sidelight bulbs/What do you use?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2012, 19:39
  4. LED Sidelight HELP!!!
    By SRI Alex in forum Electrical & ICE (including SatNav)
    Last Post: 6th September 2011, 17:10
  5. sidelight fittings
    By MrLOL in forum Vectra C / Signum Car Chat
    Last Post: 27th August 2008, 10:02
