Thread: advice need please
    Mar 2011
    accrington
    Default advice need please
    hi all, just gone to ceck oil etc, took the filler cap off and noticed a lot of creamy gunk on it,
    now its not using oil or water, no over heating, no oil in the water res at all, but bit concerned now!
    anything else should check or clea maybe
    any help be appreciated
    paul
    Dunstable
    My dad had this on his astra, was using it for short journeys only and condensation built up under the cap and mixed with the oil causing a creamy gunk. My brother bought the car and used it for longer journeys and drove it a bit harder and the gunk went
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    2 Thread(s)
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    which engine is it?, tbh its not uncommon the xep petrol enignes in corsas etc seem to suffer from it really bad, as said just condensation nout to wrry about just clean it off so it dont mix with the oil
    Mar 2011
    accrington
    hi, the engines a 2.2, what said seems to match the previous owners he only used it for very short journeys to and from work,
    ill be clocking more miles up with work, so ill keep my eye on it
    thanks for the replies
    Regular Member sdemps's Avatar
    Nov 2007
    Ayrshire
    I'd clean off the oil breather pipes then use an engine flush treatment followed by an oil and filter change. I wouldn't worry if there is no signs of losing oil or water.
  1. ebay advice , think someone is trying it on , need advice ...
    By poves in forum General Motoring Chat
    Last Post: 22nd August 2012, 00:29
  2. Need help and advice please
    By Angel1368 in forum Engine & Drivetrain
    Last Post: 9th June 2012, 11:19
  3. Need advice what would you do....
    By pipamish in forum General Motoring Chat
    Last Post: 2nd December 2011, 02:13
  4. Newbe after advice, lots of advice!
    By rb199 in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2011, 19:08
  5. Advice please?
    By RN37 VXL in forum Engine & Drivetrain
    Last Post: 16th October 2009, 17:59
