Thread: Extended wheel studs
    Regular Member Arnie1's Avatar
    Oct 2010
    Blackpool
    Default Extended wheel studs
    Does anyone know where I can get some longer wheel studs? I am thinking of getting some 20mm spacers and I have been told that I will need to get longer studs.
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Any of the wheel suppliers should be able to supply them .ie just had a look on demon tweeks web site and they supply + 13mm bolts for £1.58 or +25mm bolts for £1.70 each
    and still loving it
    Oct 2010
    Blackpool
    I would guess that I would need +25mm studs if I fit 20mm spacers?
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    you should not need them the spacers bolt to the hub and they in turn have holes in then for the wheel bolts to go in to
    Aug 2010
    Luton
    Oct 2010
    Blackpool
    I understand now. thanks lads
  1. Exhaust manifold studs
    By john norris in forum Engine & Drivetrain
    Last Post: 17th September 2012, 09:21
  2. 1.9 150, broken studs, zorst manifold.
    By graememk in forum Engine & Drivetrain
    Last Post: 10th May 2011, 15:55
  3. Floor Mat Fixing Studs
    By cerbrious in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 19:10
  4. Exhaust Studs
    By Stephen S in forum The 'Off Topic' room
    Last Post: 23rd June 2009, 23:00
