Thread: H7 HID kit
    Oct 2010
    Birmingham
    Default H7 HID kit
    just a quick question regarding the H7 HID kit. ive installed the kit and im getting different light patterns from both bulbs.
    does anyone know which way the ignitor strip on the bulb should be, at the top or bottom?
    thanks guys
    scottish region
    should be on the top mate
    Oct 2010
    Birmingham
    thanks for the quick reply
    Sodding Typical on Sea
    It does sound like the bulb is either not all the way in or at an angle, mine both sit the same way and patterns are in line.
    scottish region
    Quote Originally Posted by Derek Mc View Post
    ming is the same as dereks patterns are fine sounds like what derek said double check mate
    mumbles
    hi
    if there on a pre facelift with the stupid bulb holder adapters its easy to fit the bulb upside down which when turned on creates two lines in the road
    the little filament on the bulb should be facing up
    Dunstable
    As mentioned above, sounds like one of the bulbs are not in correctly. I had this with mine, was certain they were clipped in properly and when I looked, one of them weren't. Also it doesn't matter which way round they are, I believe they insert in different positions on the facelift yet the beam pattern is the same from each headlight. And there isn't a filament inside as it's an arc lamp
